Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Limited Slip with 3.08 gears?
Old Sep 14, 2020 | 01:03 PM
Julius Rosenthal's Avatar
Julius Rosenthal is on a distinguished road
Default Limited Slip with 3.08 gears?
I have a '93 S10 Blazer 4x4 automatic with GU4 code rear end (3.08 gears) and an open diff. All stock everything and for the most part that's how I like it. I do mostly highway driving so 3.08 gears and the mileage they offer are perfect for me. I only ever do light off-roading on fields and camp sites. The most intensive thing I do with this truck would probably be pulling corollas out of snow banks. I would like to install a Limited Slip carrier to give myself just a little bit more assurance when pulling cars or driving on wet fields, but upon quick research I can't seem to find anybody else who has put a limited slip on 3.08 gears.
Looking at parts from summit, I see this:
https://www.summitracing.com/parts/dtl-912a317 - Eaton Detroit Truetrac Differentials 912A317
Which specifies that it "fits 3.23 and numerically higher gear ratios."
Is there some inherent problem with putting an LSD on 3.08 gears?
Would it physically not fit or is there some other reason?
Has anyone done something like this before?
Old Sep 14, 2020 | 01:27 PM
Billy1820's Avatar
I’ve got that exact set up on my truck; however, ​​​you didn’t mention if you’ve got the 8.5 rear or the smaller one?
When I built my truck, I swapped rears from a 5spd that had the 8.5 rear with 308 gears. I had the smaller open rear with 342’s before I did the swap.
I put an Eaton posi in the 308 rear, and had no issues swapping from G80 to the Eaton.
toyhauler1283
Jan 23, 2014 07:46 PM
Irocz327
17
Oct 30, 2012 12:11 PM
Jase1979
Sep 13, 2012 08:28 PM
James1965
Jan 16, 2012 11:32 AM
big_blaze
Sep 22, 2008 06:49 AM
