Marine Intake
I need to know everything about everything about doing the marine intake swap. I know I need the intake, upper and lower, injectors, fuel rail, etc. But what about wiring? I have a 95 I plan on putting it in. Do I need the computer from the boat it came out of? How do I hook that up to work with the computer in the blazer? What kind of tuning do I need to do?
Thanks for the link! I'm wanting to do it because the stock injector is just awful and theres no upgrade options for it. I hear the Marine Intake is a big step up in performance and that you can actually tune it.
You can upgrade/replace the spider with the non poppet style. The only real advantage or gain you are going to get is if you use the marine intake in conjunction with a turbo or supercharger. Otherwise you are really just spending a bunch of money on a different fuel delivery system that does the same thing as your stock setup. The only thing it will add is a slight bit more reliability and higher fuel flow ability. Wynjammer makes a setup that is on par with the marine intake but bolts I'm place of the factory spider injector. It has higher and tunable flow rates but again unless you are using a power adder just dumping more fuel in the motor is not going to gain you any power. If you just want to do it because you can go for it but I say if it ain't broke don't fix it!
. Thog for president!!!
