Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
rea axle dual conversion
Old Sep 8, 2011 | 05:38 AM
bobbyb64's Avatar
bobbyb64 is on a distinguished road
Default rea axle dual conversion
Hey Guys,
Can anyone tell me how a single wheel axle can be converted into a dually?
What mods and parts are required?
Prishiate it.
Old Sep 8, 2011 | 07:50 AM
What are you working with to start? Dually axles were on 1-tons most commonly.
Old Sep 8, 2011 | 10:51 AM
bobbyb64's Avatar
Like going dually on a K5 Blazer. Is there anyways of converting the original axle to a dually?
Old Sep 8, 2011 | 10:56 AM
Anything is possible with time & money, but to make a dually out of a standard 10-bolt or 12-bolt rear axle as found under a K5 in stock form, you would have to get longer wheel studs & likely get custom inner/outer rims to bolt through like a dually does. Not really worth it, especially if you aren't going to use the truck under circumstances that a dually typically would be used for (hauling heavy loads, etc).
If you really want to do it, I would swap in a dually 14BFF & get the proper wheels. If you find a full 1-ton dually, take the front & rear axles and swap them over to your truck then you can use the same rims all the way around.
Old Sep 9, 2011 | 03:46 AM
bobbyb64's Avatar
You mentioned that going dually would be used for heavy hauling , I m looking for better traction offroad besides being able to tow a heavy trailer. Do you think this would help?
Many Thanx.
Old Sep 9, 2011 | 07:45 AM
IMO, converting to a dually will hurt more than help offroad.
How heavy of a trailer are you thinking of hauling? What would your tongue weight be (what's transferred to the truck)?
Old Sep 10, 2011 | 01:29 AM
abig84's Avatar
yeah the true dually axle is a 14bolt axle that is gonna hang way lower then your stock axle and also weighs a bit more. instead of messing with whatever stock axle you have, if youre really concidering this. just buy a dually axle. should be upwards of $100. they are all over. i had a dana 70 dually axle laying around here i couldnt give away for few years. finally someone bought it for $10 on ebay
also (most) dually axles are gonna be 8 lugs so youre gonna need new rims too
Old Sep 11, 2011 | 01:16 AM
bobbyb64's Avatar
I d be towing two types of trailers one s a camper trailer and the other would be a simpler flat trailer carrying a rock crawler on different occasions.
I m not sure how tongue weight s figured out but I kow the crawler doesnt weiht more than a 1.5 ton.
Many Thanx.
Old Sep 11, 2011 | 01:27 AM
bobbyb64's Avatar
Originally Posted by abig84
yeah the true dually axle is a 14bolt axle that is gonna hang way lower then your stock axle and also weighs a bit more. instead of messing with whatever stock axle you have, if youre really concidering this. just buy a dually axthle. should be upwards of $100. they are all over. i had a dana 70 dually axle laying around here i couldnt give away for few years. finally someone bought it for $10 on ebay
sounds good. I d probably doing that. prishiate the tips. what s your opinion about having a dually for offroad use and not just for hauling?
Old Sep 11, 2011 | 01:36 AM
bobbyb64's Avatar
By the way swart can you explainmore on how it would hurt off road? I ve been under the
impression that I d have better traction like seen on tractors in farms .
