Tuning for gas mileage?
Does anyone know what is involved in tuning an engine strictly for better fuel economy? I don't mind a little loss in power for better gas mileage. I've heard something about changing the fuel injection timing for this purpose, but I'd appreciate any input.
RE: Tuning for gas mileage?
I don't know about tuning it to get better mileage, but you can use a ECU programmer.
There are several things you can do, to gain economy AND power. Just to name a few. -Replace OE exhaust with an aftermarket -get a K&N intake or drop-in filter -Electric radiator fan |
Thanks I'll try these things when I have the money...
I have heard before that an aftermarket intake can wear on the long term life of the engine. Is this possible? I'd prefer a more efficient one over one that's strictly for power and is harder on the engine. Maybe the K&N is more efficient and only helps? I'm new to these things. Thanks for the help.
An aftermarket setup, works just as good, if not better than factory, durability wise, the only issue people have with aftermarket setups, is the same you might get from your KN&N drop in... Too much oil on the filter will cause the MAF to get oil on it, and stop it from working properly...
The solution to that, is after the filter is oiled up, take a vacuum or shop-vac to the filter to get any excess oil... |
Use synthetic oil and make sure your tires are always filled to spec. You will see a huge difference at the pump.
magnets, tornados, and 5 buck resistor lol
you have a blazer you will be lucky to get 20 miles in the city a intake will help with power and gas mileage just dont beat on it if you want good gas mileage. also an exhaust will help. i have a 94 cpi with headers and exhaust and a k&n intake and get about 19-20 city and almost 25 highway when im nice to it
[align=left] [/align] |
Before I put all my extra crap and the bigger tires on, as long as I babied the thing, I could get 20, give or take a .5...
putting on an air intake doesn't hurt the motor like you were told all it is ment for is to increase you air to fuel ratio so there is more air then fuel thus extending you mpg an exhaust helps as well the less stress on the motor the better the mpg you want all the miles in the world to the gallon and have a pretty big budget then you can do this : electric fans, electric water pump, electric with override to manual power steering and those alone will eliminate so much stress on the motor so you will get more miles to the gallon and the cooler your motor is the less fuel you burn if you want to know were to get the power steering unit flaming river has them and as for everything else i would try summit
| All times are GMT -5. The time now is 02:21 AM. |
