Shows & Clubs Know of a show to which you can bring your Blazer? Post it! Have a car club for Blazers? Tell us!
OFFROADING!!!! North Carolina
Old Apr 7, 2009 | 09:51 PM
  #31
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
Havnt had a chance to mess with it yet... I need to get some tranny flush. I spoke with some of the local mechanics and they say it sounds like the trans is fine, but just needs a good flush and refill.
Old Apr 8, 2009 | 10:34 PM
  #32
Default Update:
Well, its not good news, but not bad either I guess...
Flushed the tranny and pulled the pan... Clean as a whistle!!
As I was sitting under the Blazer, decided to turn the front output shaft and noticed a gritty-grinding sound... Here comes the fun...
Unscrewed the transfer case fill and drain plugs and it is absolutely nothing but water and mud, THICK MUD. One question (I have already checked the search option) How do you, or would it be wise, to flush the transfer case? Or just go ahead and take it off the tranny and go through it while I'm at this point?
Thanks, John
Old Apr 8, 2009 | 11:19 PM
  #33
SockJock's Avatar
SockJock is an unknown quantity at this point
Mud and water, not good. I'd drop the tcase and pop it open to get it cleaned out right.
Old Apr 8, 2009 | 11:41 PM
  #34
^^ exactly what I was thinking, I mean, I've already flushed and taken the pan off the tranny...
Old Apr 9, 2009 | 08:23 PM
  #35
WolfPack's Avatar
Yes...definitely drop it. Take some pics when you pull it apart. Id be interested in the process to disassemble it!
Old Apr 12, 2009 | 08:11 PM
  #36
dropped the trans case and totally disassembled it. It was horrifying! Mud and water = rust everywhere! I soaked with kerosene and reassembled/ installed yesterday. Took her out for a run a few min ago and the transmission is totally done guys IT WILL NOT SHIFT OUT OF 1st! FU@#$%!!! Sooo...... Any of you guys know if the New Process 207 transfer case will fit a th350 chevy transmission without any adapters???
Old Apr 12, 2009 | 08:19 PM
  #37
UPDATE:
I can do a v-8 swap, all i need is headers ($200) I have a 350 and a 700r4 trans in the Camaro I have been working on. (Non highway use)
or... get a transmission from pull-a-part in charlotte for about $80 (I have to pull it) and get lucky if it works right...
Old Apr 13, 2009 | 11:19 AM
  #38
SockJock's Avatar
You could get the used trans and rebuild it for approx. $200 in parts, but the special tools for the job is what costs.
I'd jump on the V8 swap since you've already got that motor and trans, but you'll be needing to beef up the rest of the drivetrain to handle it.
No matter how you go, you're gonna be spending more money one way or the other.
Old Apr 13, 2009 | 09:33 PM
  #39
Actually I found out that no matter what, a 2wd tranny has a main shaft that is about 3-4 inches too long. However, I do have a secondary option. One of my commercial accounts has a 700r4 from a 4.3 blazer (I know for sure this will bolt up to a small-block) And I have a freshly rebuilt 327 that I did have in my Camaro. So... a 327 with a 700r4 should be some fun! But this wont be for a while...
Old Apr 18, 2009 | 12:44 PM
  #40
GABlazer's Avatar
GABlazer is on a distinguished road
327 with a 700r4 would be some fun..... now u have me thinking U might wanna go ahead and beef up that diff with a ford 9 bolt help harness that power where r those trails at? I live in dillard GA just below franklin NC how far away are yall?
