Code 43 ESC Failure corrected
Old Aug 14, 2010 | 12:13 PM
mr.vls's Avatar
Default Code 43 ESC Failure corrected
I first replaced knock sensor (which was a real pain to do) and that did not correct the problem so today I went to the junkyard and pulled a ESC moudle from an 89 Jimmy and installed it in the junkyard parking lot and fault did not come back once I started the car. The junkyard charged me a grand total of $6.50 compared to about $60.00 new from NAPA.
Old Aug 14, 2010 | 12:53 PM
ohsofly's Avatar
60 is the cheap one at napa, I got that one for mine, didnt have any code, just thought it was a good idea. They also had one for 150.. The stuff that fits in your pocket at the wreckers is usually free where I go
Old Aug 14, 2010 | 04:41 PM
mr.vls's Avatar
The junkyard I go to is a U-Pull it and they usually do not charge very much for anything that I am looking for. Lots of times I get some nuts or bolts that I need and they do not bother charging. I just keep it honest and do not mind paying the small amounts they charge. Also if the item is defective you can return it for a replacement or cash back.
Old May 22, 2011 | 11:44 AM
btb1003's Avatar
btb1003 is on a distinguished road
Where did you locate the ESC module?
Old May 24, 2011 | 08:53 PM
mr.vls's Avatar
The ESC is mounted on the firewall to the left of the distributer. If your asking where I purchased mine it was at a local U-Pull it Junkyard and I pulled it off of another Blazer. I swapped in the junkyard ESC in the parking lot and corrected my fault code.
Old May 25, 2011 | 09:02 AM
btb1003's Avatar
All I see on the firewall are twolittle black boxes just to the left of the master cylinder. Is that it?
Old May 25, 2011 | 09:17 PM
Leeann_Bravada's Avatar
mr.vls has an '89. What are you driving?
On a '93-'95, for instance, Code 43 is Knock sensor signal was either above 3.5 volts or below 1.5 volts for at least 20 seconds. There is no ESC.
Old May 26, 2011 | 07:51 AM
btb1003's Avatar
'93 S10 Blazer 4X4 Tahoe
Old May 26, 2011 | 10:40 AM
You don't have an ESC; that's handled by the ECM. That code is for a knock sensor on your truck. You have 2: one near the spark plugs in the driver's side head and one in the back of the passenger side head towards the firewall.
JcP
Apr 4, 2015 09:39 PM
Floridagirl_1021
Jul 7, 2013 04:44 PM
BlazintheS-10
May 22, 2011 02:49 AM
btb1003
May 21, 2011 05:21 PM
