ak's 2000 4door
1 Attachment(s)
figured id throw some pics up now that its running again, it blew the intake/headgaskets and hydro locked 2 years ago after being beat on by its previous owner. I swapped in a running w-vin engine with 110k on the clock last year, but forgot to do the gaskets after letting the engine sit for a year. the intake or headgasket started mixing coolant and oil so I did a full topend rebuild last month, along with external fluid coolers.
runs like a champ now, even with bad o2 sensors! its got every option except zr2/sunroof. full leather, a/c, all power, heated, 4 button 4wd, ls/lt package. https://blazerforum.com/forum/attach...ine=1384055817 future mods: electric fans, air shocks, retrofit headlights, led board tails, led interior conversion, shaved badges/trim, decent soundsystem, single svt cobra muffler. |
3 Attachment(s)
heres a few more pics. went and tested the 4wd, 4hi works great from neutral or "on the fly" but it didn't want to go into low and I have no clue if the axles were locking/engaging posi when they were supposed to be.
https://blazerforum.com/forum/attach...ine=1384707905 https://blazerforum.com/forum/attach...ine=1384708100 https://blazerforum.com/forum/attach...ine=1384707905 http://i307.photobucket.com/albums/n...ps1729fcf6.jpg I have a wicked squeak in the front drivers side suspension, guess its time for a urethane master bushing/mount kit. |
recently shaved the side strikes and badges. swapped out the door control panels for bravada smartrak woodgrain panels and a tachometer cluster too.
6 Attachment(s)
im thinking im going to start the headlight retrofit very soon. just cant decide if I want to work off of a set of clear 98+ s10/blazer lights using oem single hid or dual halogen projector units. also thought about trimming my grille and using sonomas with projectors in the fog spot.
heres a few retrofits Ive done. 400ex etched lenseshttps://blazerforum.com/forum/attach...ine=1386447285 halogen cavailer set https://blazerforum.com/forum/attach...ine=1386447285 https://blazerforum.com/forum/attach...ine=1386447285 lexus sc400 cavalier retrofit with bosch micro highbeams https://blazerforum.com/forum/attach...ine=1386447285 https://blazerforum.com/forum/attach...ine=1386447285 https://blazerforum.com/forum/attach...ine=1386447285 |
1 Attachment(s)
i soldered up some leds into the upper turn signals today, using the stock socket. https://blazerforum.com/forum/attach...ine=1386464632
To get it into four low you have to switch into neutral. Take lots of pics, will be interesting to see how you retro some projectors into there.
