look what i scored first gen clear tails
Old Oct 26, 2009 | 05:30 AM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
Default look what i scored first gen clear tails
so i was just messin around on ebay lastnight and i found these for $26.00 and they cost $25.00 to ship so i got them for $51
http://www.hdcautosports.com/hdcauto...TL-CS1082C.jpg
heres some more auctions for the same thing for all that are interested
http://cgi.ebay.com/ebaymotors/1982-...d=280390787433
http://cgi.ebay.com/ebaymotors/1986-...d=300342858974
thoughs were all i could find tho, good luck
Old Oct 26, 2009 | 06:14 AM
Sisk's Avatar
Don't really like those...but to each his own. FYI - They look fully clear. You will probably have to replace the stock bulbs in your tail lights with red ones...
Old Oct 26, 2009 | 10:50 AM
neo71665's Avatar
Hope you good buddies with the cops. If not you are about to be
Old Nov 10, 2009 | 10:24 PM
old skool luvr's Avatar
Sisk is right, and so is neo.
if there isn't any red refector in the housing, they're not street legal. funny though, when i was looking @ the auction, the pic looked like it was a B & W pic.
my brother has the same tails in his '83, but his have the red reflector and inner lens (for the signal/brake). looks pretty good on his shiney black Dime.
Old Nov 10, 2009 | 11:23 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
i never get hassled for mine new cars now come with all clear lights so they dont bother you as much as they use to
they are still illegal unless you add a red reflector somewhere on the back
Old Nov 11, 2009 | 07:08 AM
CraigSnedeker's Avatar
Those are NICE lights!! =D
Old Nov 11, 2009 | 09:16 AM
Sisk's Avatar
I think that's the problem we were bringing up though...they look fully clear with no reflectors or anything of color on them. You'd need to have red bulbs and a red reflector in there somewhere...
Old Nov 11, 2009 | 10:20 AM
oktain's Avatar
It's like the clear corners I installed, so I wouldn't get hassled, I bought a set with an orange reflector on the side.
Old Nov 12, 2009 | 03:17 AM
loomdog32's Avatar
loomdog32 is on a distinguished road
I like the look of the clear lights.. There are too many legal reasons not to tho..
Most of not all states (im assuming your in the USA), require rear stop lights to have reflective red lens (to allow the vehicle to be seen at night from a distance with the lights off).. This is also the same argument with tinting tails
Below is examples of CA and TX laws
CA Vehicle Code - Division 12, Chapter 2, Article 3 » Section 24600
(e) Taillamps shall be red in color and shall be plainly visible from all distances within 500 feet to the rear except that taillamps on vehicles manufactured after January 1, 1969, shall be plainly visible from all distances within 1,000 feet to the rear.
Texas Code 547:
Sec. 547.302. DUTY TO DISPLAY LIGHTS. (a) A vehicle shall display each lighted lamp and illuminating device required by this chapter to be on the vehicle:
(1) at nighttime; and
(2) when light is insufficient or atmospheric conditions are unfavorable so that a person or vehicle on the highway is not clearly discernible at a distance of 1,000 feet ahead.
(b) A signaling device, including a stoplamp or a turn signal lamp, shall be lighted as prescribed by this chapter.
(c) At least one lighted lamp shall be displayed on each side of the front of a motor vehicle.
(d) Not more than four of the following may be lighted at one time on the front of a motor vehicle:
(1) a headlamp required by this chapter; or
(2) a lamp, including an auxiliary lamp or spotlamp, that projects a beam with an intensity brighter than 300 candlepower.
Sec. 547.3215. USE OF FEDERAL STANDARD. Unless specifically prohibited by this chapter, lighting, reflective devices, and associated equipment on a vehicle or motor vehicle must comply with:
(1) the current federal standards in 49 C.F.R. Section 571.108; or
(2) the federal standards in that section in effect, if any, at the time the vehicle or motor vehicle was manufactured.
Sec. 547.322. TAILLAMPS REQUIRED. (a) Except as provided by Subsection (b), a motor vehicle, trailer, semitrailer, pole trailer, or vehicle that is towed at the end of a combination of vehicles shall be equipped with at least two taillamps.
(b) A passenger car or truck that was manufactured or assembled before the model year 1960 shall be equipped with at least one taillamp.
(c) Taillamps shall be mounted on the rear of the vehicle:
(1) at a height from 15 to 72 inches; and
(2) at the same level and spaced as widely apart as practicable if a vehicle is equipped with more than one lamp.
(d) A taillamp shall emit a red light plainly visible at a distance of 1,000 feet from the rear of the vehicle.
(e) If vehicles are traveling in combination, only the taillamps on the rearmost vehicle are required to emit a light for the distance specified in Subsection (d).
(f) A taillamp or a separate lamp shall be constructed and mounted to emit a white light that:
(1) illuminates the rear license plate; and
(2) makes the plate clearly legible at a distance of 50 feet from the rear.
(g) A taillamp, including a separate lamp used to illuminate a rear license plate, must emit a light when a headlamp or auxiliary driving lamp is lighted.
Sec. 547.323. STOPLAMPS REQUIRED. (a) Except as provided by Subsection (b), a motor vehicle, trailer, semitrailer, or pole trailer shall be equipped with at least two stoplamps.
(b) A passenger car manufactured or assembled before the model year 1960 shall be equipped with at least one stoplamp.
(c) A stoplamp shall be mounted on the rear of the vehicle.
(d) A stoplamp shall emit a red or amber light, or a color between red and amber, that is:
(1) visible in normal sunlight at a distance of at least 300 feet from the rear of the vehicle; and
(2) displayed when the vehicle service brake is applied.
(e) If vehicles are traveling in combination, only the stoplamps on the rearmost vehicle are required to emit a light for the distance specified in Subsection (d).
(f) A stoplamp may be included as a part of another rear lamp.
Old Nov 12, 2009 | 12:34 PM
neo71665's Avatar
If you also dig in the front requires amber reflectors. Most of the time you can get by with clears on the front but on the rear they will nail you.
