New tail lights
Old Jul 13, 2020 | 06:40 PM
Hadyss's Avatar
Default New tail lights
Picked up a new set of tail light and just wondering if anyone has an idea how to wire the led rings up. They have separate power wires for each ring. Was thinking just wire them to the parking lights.
Guy bought them for his 05 blazer but sold it 2 years ago so got them for $60 they are brand new still
Old Jul 13, 2020 | 06:51 PM
I could see them being useful for either running lights or brake/turn signal lights.
They would look really neat as the only running lights in the assembly (that would require actually cutting the leads on the factory tail light bulb sockets and running them to the 12v+ for the LED's, and just tapping in to ground to complete the circuit).
On the other hand, they would give off more lighting for the brake/turn signals if they were tapped into that circuit to come on with the original bulbs.
Guess it's really just up to you and your personal preference. I myself would lean towards using them as running lights
Old Jul 13, 2020 | 07:19 PM
Hadyss's Avatar
That’s a good idea and I have no issue cutting a wire to do it
Old Jul 13, 2020 | 07:46 PM
A side effect and possibly a benefit to disabling the incandescent bulb as a running light, you don't have to worry about it melting the aftermarket housing. I see so many aftermarket taillights melt right above the bulb, because the bulb sits so close to plastic inside. Look at just how small that red lens is inside the light and the small amount of space around it. The heat from the bulb has nowhere to go and it ends up boiling the plastic lens.
This is of coarse not an issue if you install LED bulbs in place of the original glass incandescent bulbs...
When I bought my aftermarket lights years back, I didn't even install them until I got LED bulbs to put in them, so I could prevent that from ever happening. They've never had glass incandescent bulbs in them and they still look brand new to this day.
I went a little overboard with my LED install though lol. I retrofitted Osram Joule LED modules into them. I want to replace them with lights that are blacked out inside like you'rs are, I just haven't gotten around to it yet... These chrome ones fit the look when I had some chrome 16" Firebird wheels on the Blazer at the time, but now I've got black wheels, black brush guard, etc, and the chrome sort of sticks out...
Old Jul 13, 2020 | 07:50 PM
Hadyss's Avatar
I just read the thread on your led bulbs and I was thinking it might melt and though of running to get some led bulbs but they are $30 for 2
Old Jul 13, 2020 | 09:03 PM
Hadyss's Avatar
So installed and working. I did disable the incandescent bulbs from the running lights so the rings light up instead and they look amazing
Old Jul 13, 2020 | 11:52 PM
Cool! Those do look good!
Old Jul 13, 2020 | 11:58 PM
Hadyss's Avatar
I had an issue with it yesterday I had to fix before the lights. I went and rotated my tires and discovered my front diff was locked turned out the cable was a little sticky and didn’t disengage not sure how long it was like that but an easy fix. Maybe I’ll get some gas mileage back
Old Jul 14, 2020 | 06:24 AM
Looks good! Glad you got them installed.
Old Jul 24, 2020 | 04:23 PM
Torbinator's Avatar
Torbinator is on a distinguished road
These things look great! Any clue where they came from? Id replace mine with these any day.
