12 bolt question
Old Oct 22, 2012 | 10:07 PM
jimmyjam8586's Avatar
jimmyjam8586 is on a distinguished road
Default 12 bolt question
I was looking around on the net and I found a GM 12 bolt for $80.00. It is a stock 12 bolt rear end out of a '71 Chevy pickup that supposedly still works fine. I'm not an rear end expert but from a few quick searches on the net that seems like a really good price even if the internals are damaged. All of the other 12 bolts I have seen on the net were between $400 and a couple thousand. Is there something I'm missing? Like maybe certain years are valuable and others aren't or am I just finding a bunch of over priced axles online? Thanks for the help.
Old Oct 23, 2012 | 10:47 AM
neo71665's Avatar
If its just a 2wd 1/2 ton open diff axle there's really nothing special about it. They go cheap cause guys upgrade to something better and their wife doesn't want it laying in the yard. If a 4x4 he prolly put a 14 bolt or dana under it. If it was a factory 12 bolt for a camaro or nova then yeah its a gold mine.
When I picked up my ford dana 60s I got them both for $200 cause the guys wife wanted them (well the whole truck) gone. I got $400 for the 460 alone and by the time it was parted down and all sold they pretty much paid me $2000 to haul it off and get free axles.
Old Oct 24, 2012 | 07:27 PM
abig84's Avatar
yeah 12 bolts are basically just 10 bolts with a slightly bigger ring gear. i think i gave my last one away. my only gripe with them is they are slightly rarer so if you break a axle shaft, it might be harder to find, 10 bolt shafts dont work
Old Oct 25, 2012 | 10:40 AM
Thanks for the replys. I will disregard the 12 bolt keep searching for some replacement axles. Any suggestions? I'm not an extreme off roader. I actually do substantially more highway driving than off roading and the off roading I do is more mud pits than crawling over large objects.
Old Oct 25, 2012 | 06:08 PM
neo71665's Avatar
When I first done mine I ran a jeep yj dana 30 front and ford explorer 8.8 rear. Used that setup with 33 inch tires in mud and trail rides. I got both axles from the local pick a part for $150 a piece. I wanted to go higher, bigger tires and a 383 stroker v8 to get in the deeper stuff. I was actually looking for dana 44s when I found my 60s for a song.
Old Oct 25, 2012 | 06:09 PM
abig84's Avatar
10 bolts work fine depending on horsepower and size of tires, i ran 10 bolts with 38s for many years, i think im going on about 10 years with the same axles. they were under fullsized trucks with 38s for about 6 years and the last few years been living the easy life with 33s under a s10.
so if your stock yeah just find another set of 10 bolts.
Old Oct 26, 2012 | 12:03 AM
neo71665's Avatar
They are however pass drop so the t-case has to be swapped since the s-series uses a drivers drop. Why I stuck with jeep and ford axles, was running my factory np207 t-case just fine.
Old Oct 27, 2012 | 04:24 PM
abig84's Avatar
good point. what are these axles going on? if its a s10 yeah you will need to swap transfer cases. if its a fullsize then no problem
mjsk5blazer
May 4, 2015 07:51 PM
smitty5150
Lifting Tech
Jul 16, 2011 12:35 AM
yarinzim
Mar 19, 2011 02:48 PM
clutch
Tires and Wheels
17
Feb 3, 2007 04:29 AM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
