1996 s10 (4wd) u-joint replacement
Old Jan 26, 2011 | 03:38 PM
oliver586's Avatar
oliver586 is on a distinguished road
Default 1996 s10 (4wd) u-joint replacement
Getting a lot of vibration at 45-50 mph. Crawled underneath and found a lot of play in the front u-joint. Looking for instructions on how to replace u-joint for first time DIY. Should I also replace rear u-joint at the same time for good measure? Vehicle has 158,000 miles and I don't recall ever having them replaced before.
Thanks
Old Jan 26, 2011 | 04:13 PM
I would recommend you replace both while you have the driveshaft out. There are a number of good tutorials that can be found on google so I won't go into great detail. Just make sure to mark the orientation of the driveshaft to the yoke on the rear axle as well as the orientation of the slip yoke to the driveshaft at the front. If things get put together differently than they were taken apart, it could result in a vibration.
Old May 30, 2011 | 01:33 PM
1badgtx's Avatar
1badgtx is on a distinguished road
Anyone have any feedback on these tools?
Found this on youtube cause i have to change mine also.
YouTube - ‪Service U-joints in minutes using the Tiger Tool 10105 U Joint Puller & 10202 Bearing Cup Installer‬‏
josemateos
Feb 18, 2014 10:00 AM
oliver586
Mar 9, 2011 09:35 AM
Guntheone
Dec 4, 2010 05:59 PM
97Bravada
Jan 14, 2010 05:51 PM
ejoy1220
Oct 8, 2006 06:45 PM
