1997 Bravda
Old Aug 8, 2013 | 05:57 PM
BackwoodsBogger14's Avatar
BackwoodsBogger14 is on a distinguished road
Default 1997 Bravda
Is there a way for me to disable my awd like a blazer with 4 wheel drive. But with a fuse. Or somthin
Old Aug 9, 2013 | 12:43 AM
Thogert's Avatar
The new member area is for introductions only please.
**Moved to Steering, Suspension, & Drivetrain**
Old Aug 9, 2013 | 08:10 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
no, the front axle is always engaged and doesn't have the actuator to lock and unlock it either. If you simply take out the front drive shaft you will damage the transfer case. You could either witch to a 2wd transmission or swap transfer cases with a 4x4 and keep it in 2wd, however you wont have the push buttons to change it into 4x4 or low, it could only be done manually with a wrench under the truck
Old Aug 9, 2013 | 10:17 PM
Would i ever be able to tear apart my hole dash switch the transfer case. To the same year blazer id be able to 4 wheel drive to 2 wheel drive? But keep the same look as a the bravda?
BackwoodsBogger14
Oct 12, 2013 11:29 PM
polcat1998
Mar 1, 2006 06:05 PM
drumzandrekkids
Feb 10, 2006 11:24 PM
psawatsky
Aug 6, 2005 01:48 AM
reggie4828
Engine & Internal
Jan 6, 2005 10:58 PM
