1997 chevy blazer front end squeaking
Old Jul 24, 2012 | 09:06 PM
duckland23's Avatar
duckland23 is on a distinguished road
Default 1997 chevy blazer front end squeaking
Hi My front end just started to squeak in the front end . I can hear it more when I move the shock tower . It sounds like its from the front shock tower . Im not sure . where are the bolts for the shock towers on top . are they under the anti lock brake unit .
Old Jul 26, 2012 | 09:29 PM
johntaylor625's Avatar
johntaylor625 is on a distinguished road
I had this same problem. Turned out the lower ball joints just needed greased
Old Jul 26, 2012 | 10:38 PM
duckland23's Avatar
I got a grease gun from a friend and am going grease them tonight . Lower and upper ball joint plus the tie rod ends . and maybe the pitman arms too .
Old Jul 27, 2012 | 07:44 AM
98blazin's Avatar
98blazin is on a distinguished road
last week we had a storm and i had to drive in 12-14'' of water and a couple days later a squeak appeared. i grease all ball joints, inner/outer tie rods, pitman and idler arms, gave a shoot of lubricant on the stab bar bushings and the noise is gone.
Old Jul 28, 2012 | 03:05 PM
duckland23's Avatar
Yeah I just greased the front end grease fitting . There was one zerk fitting i could not grease , I may need to pull the wheel from the right side of the truck . At one point the ball joints were changed there not from the factory . I get a poping sound sometimes when I turn the wheel on it .
A little WD-40 works wonders on squeaks on a car ot truck . I need to make sure the front end is ok .
Old Jul 29, 2012 | 12:18 PM
you may just need to turn the wheel in order to get to it. i could get to all of mine just by turning the wheel in different positions
Old Jul 30, 2012 | 08:08 PM
duckland23's Avatar
No that wont work the zerk fitting is right by the mounting bolt and I cant get the grease gun in there . Im going to have to take off the wheel to turn the zerk fitting to get some grease in it .
Old Aug 12, 2012 | 07:39 PM
loomex's Avatar
loomex is on a distinguished road
Go to an auto parts store or even Sears and get a needle adapter for the grease gun. I had the same issue
BassHog
Sep 22, 2014 01:47 PM
Bradley2424
Mar 19, 2010 01:20 PM
blazernoobie
Jul 13, 2009 08:58 PM
eknox327
May 16, 2008 12:33 PM
tpendergraft85
Feb 17, 2006 07:10 AM
