1998 blazer 4x4 issue
Old Jul 19, 2012 | 10:23 PM
jrb_fishy's Avatar
jrb_fishy is on a distinguished road
Default 1998 blazer 4x4 issue
ok i was under the infamous blazer today you can hear the transfer case lock in and the driveshaft does not spin when its locked but the wheels do without the other turning opposite from front differential not exactly where to look now or where the problem would lie
Old Jul 20, 2012 | 05:53 AM
Your front axle is not locking in. One of the most common and well documented 4wd problems on this site.
Old Jul 20, 2012 | 12:46 PM
jrb_fishy's Avatar
i tryed to find problems on this yesterday and i could not find any could you please narrow that for me and let me know on which area i can be searching for this ever post i have made you always reply your like the all knowing blazer guy thanks for the help and the fast responding
Old Jul 20, 2012 | 08:38 PM
jrb_fishy's Avatar
ok so i just had it right off the ground on stands and tryed both 4hi and 4lo and i can hear it clicken in the front right at the diff i am going to think its the actuator on this one but not sure i could use some insight
Old Jul 21, 2012 | 09:33 AM
Check out the tech article link in my signature. In that thread, look for a thread with 'clicking' in the title.
Old Jul 21, 2012 | 07:31 PM
jrb_fishy's Avatar
thank you so much man that helps alot
Old Aug 12, 2012 | 04:38 PM
jrb_fishy's Avatar
i was reading your thread on the clicking and it is either a vac problem or a spring issue but because its not locking in at all i dont know which to start with the vac or the spring i have replaced both cv axles and i am not sure when this started i have noticed my vac lines have some problems found one near the master cylender that had a leak if you were me where would you start ? i have the nv233 transfer casr
Old Nov 10, 2012 | 12:15 PM
jrb_fishy's Avatar
ok so update the clunking was a badly broken cv axle the inner joint was torn apart no rip in the boot but when i took it out from the diff the inner just pointed at the ground got it replaced i still dont think my 4hi is engauging properly i have to check the other cv axle and the actuator
quick711
Jul 12, 2013 07:56 PM
Louie95
May 8, 2012 02:21 AM
gabhanjacisa
Mar 27, 2011 07:14 AM
85z28
May 20, 2010 07:49 AM
TheNick
Tires and Wheels
Apr 26, 2007 05:01 AM
