1998 chevy blazer 4x4 problem ..please help
Old Feb 16, 2016 | 12:38 PM
banditbo43's Avatar
banditbo43 is on a distinguished road
Default 1998 chevy blazer 4x4 problem ..please help
hey guys.. i have replaced everything.!..still wont work.. ive replaced actuator under battery, the cable, the actuator switch on transfer case, switch in dash..checked fuse.. it sounds like its engaging but its not..please help..
Old Mar 10, 2016 | 03:59 AM
Maefield's Avatar
Maefield is on a distinguished road
Vacuum leak? On my 1985 s10 blazer, the same thing happened in a foot of snow. I could put it in 4 high and 4 low but the front tires weren't engaging. One of the vacuum lines came off the 4x4 actuator. But even after putting it back on it would take a little while to kick in because of other small leaks. Works perfectly after replacing a few hoses.
Old Mar 10, 2016 | 03:54 PM
Only a few more parts to replace before everything has been replaced! More accurately, you haven't guessed the right part yet Time to stop guessing, and start diagnosing.
We need more info in order to help you. 3 button switch on the dash? Have you checked both terminals of all fuses in both fuse panels with a test light or DVOM, with the ignition on, engine off? That is the only accurate way to test a fuse. With only the right front wheel off the ground, engine at idle, transmission in park or neutral, select 4HI: can you rotate the right front wheel by hand?
chris nelson
Apr 27, 2014 07:04 PM
dimundo
Mar 17, 2013 12:19 AM
bcn
Aug 14, 2009 10:37 AM
aaronjohn20
Jul 8, 2009 05:53 PM
mrartie
13
Jan 2, 2007 09:28 PM
