2000 4x4 blazer ball joints?
Old Jan 21, 2014 | 03:11 AM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Originally Posted by Captain Hook
Using a chisel of any kind, you run the risk of deforming the control arm. Dremel is fine, should have her done by June I bought one of these for this exact job. Figured it would last 6 months, that was 5 years ago: 4-1/2" Angle Grinder Grind off all 8 rivet heads in under 10 minutes.
i like the angle grinder i just gotta figure out a way to get up there and get it while my truck is down. the guy at autozone told me the Dremel would work fine those rivets look like tough customers though lol ill figure it out
Old Jan 21, 2014 | 01:59 PM
sky_blazer's Avatar
alright i was able to borrow an angle grinder from my boss at work and i grinded off the heads on the ball joint but it wont budge. which side am i supposed to grind off? i did the top of the lower control arm
Old Jan 21, 2014 | 02:34 PM
Tops of both joints. Use a center punch, (one with a good point) and put a dimple as close as you can to the center of each rivet. Use a 1/8" drill bit and drill into each rivet about 1/4". Use a drift, (center punch without a point) and pound the rivets out. The center punch dimple will keep the drill bit from walking. The 1/8" hole will allow the rivet to contract when you use the drift. Couple of good whacks with a BFH is all it'll take.
Old Jan 21, 2014 | 07:01 PM
sky_blazer's Avatar
thanks bro you saved the day got it out and new one in put it all back together took her for a drive no clunk at all quiet even brakes better. now i can say i have replaced ball joints lol
Old Jan 21, 2014 | 07:27 PM
Good job, glad you got her. Not much to it when you know the tricks You really don't need to remove the knuckle to do the upper ball joints. Just grind the rivet heads off, drill 'em and knock 'em out. For the lower, it gives you more room if you remove the knuckle, but, you have to support the lower control arm with a jack so that when you whack the rivets, the control arm is solid.
Old Jan 23, 2014 | 02:38 PM
sky_blazer's Avatar
thanks i skipped on the upper for now since it was pretty firm still and if i need to do it i know how to do it now. as for the other side the PO replaced both of them so when that time comes it will be even easier. good thing about these older vehicles people worked on them in the past lol
g_mike
Sep 4, 2011 08:33 PM
willy4820
Jan 8, 2011 09:41 AM
Deathjester
May 9, 2010 05:52 PM
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
