2000 blazer, limited slip differential
Old Dec 27, 2013 | 12:25 PM
jbmw64's Avatar
jbmw64 is on a distinguished road
Default 2000 blazer, limited slip differential
Hi, i have a 2000 chevy blazer that the rear differential whines. I got a replacement and when i took cover off to change gear oil i noticed that it was a limited slip. The one in the blazer now is not, if i put the limited slip in, does the front differential have to be a limited slip also?
Old Dec 27, 2013 | 01:20 PM
swells87's Avatar
swells87 is on a distinguished road
no the front does not need to be limited slip as well, what did you get for a replacement?
Old Dec 27, 2013 | 03:21 PM
jbmw64's Avatar
The replacement came from a 2000 blazer, with a lot less miles than my original has.
Old Dec 27, 2013 | 03:34 PM
swells87's Avatar
ok, so the new one you got has the G80 in it, did you get the entire rear axle? If so just make sure that the gears match with your front end, so if your new rear end is 3.73's make sure you front end is as well. Lockers wont make a difference if you only have it at one end but gears will, they need to match front and rear.
Old Dec 27, 2013 | 07:41 PM
jbmw64, inside the glove box there is a white sticker with a bunch of 3 character codes. Post all of the codes that start with "G".
Old Dec 27, 2013 | 08:16 PM
jbmw64's Avatar
The only code that start with a g is GU6. So mine has 3.42 gears. The new one i picked up has 3.73 gears. Darn, should have checked closer. Thanks for all the help.
Old Dec 27, 2013 | 08:25 PM
GU6, without the G80, is an open 3.42:1 The G80 option is limited slip and most likely 3.73:1
The G80 was also available with 3.42:1 (I have one). Are you sure the new one is 3.73:1? It's usually stamped on the forward side of one of the axle tubes, probably need a wire brush to find it... and read it
Old Dec 27, 2013 | 08:44 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
The GU6 G80 axles are out there, they are just a pain in the *** to find. If the g80 still works it will go much better in the snow and mud.
Old Dec 27, 2013 | 09:28 PM
jbmw64's Avatar
Yes i am sure it is 3.73. I took the cover to change gear oil and it is stamped on the ring gear. I would love to get a G80 in 3.42:1 so i will keep looking. Thanks
Old Dec 27, 2013 | 09:35 PM
When you go to the boneyard, look on the RPO code sticker for GU6 and G80. The GU6 is the ratio you need, and there's ton of them out there, should be easy to find one. The GU6 without the G80 option will get better fuel mileage, but with the G80, you'll get better traction.
