2000 blazer will not go to 4wd
Old Dec 12, 2010 | 05:04 PM
kennystorie's Avatar
kennystorie is on a distinguished road
I press the button to go from 2hi to 4hi and the light stays flashing and never goes into 4wd i have to press the 2wd button then it stays on and the 4hi light goes out and all i have is 2wd . What could this be? its snowing like crazy help!!!
I have read it copuld be the acuator . how do i check it and were is it?
Last edited by swartlkk; Dec 12, 2010 at 05:14 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 12, 2010 | 05:14 PM
All the information you need is at your finger tips. Check the Tech Article (DIY) Index link found in my signature and look at the 4wd threads in there as a start.
And please use the edit feature to include extra information in your post if another member has replied.
Old Dec 12, 2010 | 06:26 PM
i cant find my model i have a 4 button panel in blazer its an lt all the lights just flash when i hold them down and the only light that stays on when i press it is the 2wd light it just stays in 2hi no matter what button i push it has the awd feature it dont work either.
Old Dec 12, 2010 | 06:31 PM
4-button == NV236. Is the service 4wd light on? Have you checked the electrical connections at the dash switch, the TCCM, and the encoder motor for corrosion and cleaned them with electrical cleaner?
Old Dec 13, 2010 | 07:59 AM
the 4wd service light is not on and all connections are good.
do you think it could be the acuator or just a vaccum line cracked
Last edited by swartlkk; Dec 13, 2010 at 04:40 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 13, 2010 | 10:39 AM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
did your 4x4 work before?
if it doesn't it could be the encoder motor when i first got my blazer i could push the button and it would flash but not engage 4x4. could be the vacuum actuator which is under the battery tray.
check out this article: https://blazerforum.com/forum/tech-articles-diy-29/4x4-no-worky-maybe-will-help-7180/
also i've heard of a sensor on the front differential than can be unplugged and the 4x4 will not work.
Old Dec 13, 2010 | 04:04 PM
hey guys thanks i checked the accuator under the battery and traced the vacuum line to the T over top the distributor and the line was broken at the t i repaired it and vola!!! 4wd works perfect again..... thanks i had no idea where or how to start trouble shooting this....
justblazin1
Oct 19, 2014 11:12 AM
OneBaddAssZ71
Jan 27, 2013 06:38 PM
csifmh
Jan 6, 2012 02:31 PM
LYK2ROC
Dec 5, 2008 07:08 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
