2000 LT chev blazer 4 low issues
The truck used to shift fine many times to 2hi and 4 auto and back to 2 high. I made a mistake and hit 4 low today after work and now it is stuck there. Is the TCCM bad if b4 it would switch often from 4 high to 2 high and 4 auto?
Encoder?
Help?
The lights in the dash show 4 low and when I press 2 high or 4 auto the transfer case makes noises and the tccm clicks. I took off the passenger side kick panel and took out the plugs off and they seem free of corision. The service 4wd is off.
Encoder?
Help?
Last edited by swartlkk; Feb 25, 2011 at 08:20 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Got the truck out of 4 lo by just playing with the buttons and trying lots and lots of times. for awhile it was stuck in N and no lights would come on on the dash or the switch panel. Finally engaged 2H. 4H and auto 4 work fine...
So
you guys think its a vaccum leak huh? hmmm....cheaper than a TCCM or encoder.
One thing-Under the hood, there is a buzzing sound sometimes when 4 wheel is engaged. If I press on a a rubber round thing near the firewall the buzzing goes away...any hints?
So
Last edited by swartlkk; Feb 25, 2011 at 01:58 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Kimosabe
Aug 29, 2010 04:23 PM
Stng5pnt8
Dec 29, 2008 07:36 PM
kc2iyh
Oct 23, 2007 02:14 AM
