2001 blazer lift help!?
Old Oct 19, 2011 | 05:09 PM
warthogdriver's Avatar
phewwww...ok in my case i am in the clear....2 inch body lift...5" suspension lift...jk
Old Oct 19, 2011 | 05:14 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Ha your truck pulls it off. But the guy driving down the road with giant tires and their frame only 7" off the ground, it just don't look quite right.
Old Oct 19, 2011 | 08:30 PM
racer1044's Avatar
racer1044 is on a distinguished road
How are you going to have "giant tires" with a two inch BL? The purpose of a body lift it to make room for bigger tires. And spending the 1800-2000 dollars on a 5 inch suspension lift that really does no more for you off road than allow room for larger tires and increase your ground clearance a few inches is very unpractical in my opinion. No offense to anyone who has a suspension lift. But i would take that money and sas. I have a 2inch bl and a slight torsion twist with shackles in the rear with 31's for now. Perfect lift for a DD on a budget.
Old Oct 19, 2011 | 08:37 PM
gatorboy44's Avatar
your set up may lookgood, not all of them do.
ballincopenhagen's Avatar
ballincopenhagen is on a distinguished road
i cranked my passenger side all the way in and left the driver side where it was... she still doesnt sit level and i have no idea why i think i might have worn out springs up front any ideas? and today someone told me if i flip my leafs springs itll add a few inches any thoughts on that?
Old Oct 19, 2011 | 08:42 PM
gatorboy44's Avatar
I have the same problem one tbar bolt is all the way in and the other is way out and is new. I assume they can wear out so I'm gonna replace the other.
Old Oct 20, 2011 | 08:51 PM
racer1044's Avatar
I wouldn't flip the leaf spring. Try an add a leaf to level it out if its the rear. Find a level spot and take some frame measurements to see where you stand with the height. Also check your torsion mount bushings. I replaced mine after 217xxx miles and they were horrible. Put the new moog ones in took about an hour and the truck handles better and actually sits more level.
Old Oct 20, 2011 | 08:59 PM
i took measurements of the bumpers cause it was the easiest but there really isnt anywhere thats level in the blue ridge mountains. my bushings are probly dry rotted everything is rusty cause my truck was originally purchased in ny. how much will replacements set me back?
Old Oct 21, 2011 | 07:52 AM
gatorboy44's Avatar
I didn't know the mounts wore out
Old Oct 21, 2011 | 05:21 PM
davedidit's Avatar
davedidit is on a distinguished road
2" shackles add a leaf rear
T-bar crank
Pro Comp 9000 shocks
urethane bushings all 4 corners
31x10.50x15 BFG KM2's
no prob.
