There is not an inner seal. If your seal failed that quickly, either it improperly installed, the bearing is bad, or the seal surface on the axle is damaged. Be sure to check when you install the new one. BTW, National seals are better than Timken, IMO.
What do u mean by if the seal surface is bad how would I check that.
Also another question would over filling the rear diff make it leak.
When I replaced the seal I also replaced the bearings since I had it torn apart
Run your fingernail over the surface, too, to feel for grooves. Very minor ones should be ok, but not if they're deep.
Before you put the brakes back on, check for radial play in the bearing by trying to move the axle shaft up and down. It should be barely detectable, if at all.
Since it's already apart I recommend inspecting/replacing the bearing and seal on the other side as well. The missing metal from that bearing is in the case. A thorough cleaning and sticking a magnet to the cover with RTV will make your repair more reliable.
Make sure your new shaft is the same as the old. 2wd is different than 4wd, and disc rears are different from drum rears.
I just had to replace an axle shaft recently, ordered one from rock auto. It was pretty cheap. Think it was only like $50.
That's my old one compared to the new one. Kept having seal leaks as well
