2003 ZR2 Front Hubs
Old Sep 23, 2018 | 09:34 AM
gman4q2's Avatar
gman4q2 is on a distinguished road
Default 2003 ZR2 Front Hubs
Are the front axles supposed to turn when in 2wd while rotating the tire? If no, what would cause the hub to stay locked.
Thanks
Old Sep 24, 2018 | 11:02 AM
El_Beautor's Avatar
Yes, the front half-shaft (CV axles) turn when the wheels are turning. They are bolted to the hub. If you are in 2wd, then they will be disconnected internally on the front diff. They lock in to the diff when you select 4wd.
Do you believe that your 4wd is engaged even when 2wd is selected? What 4wd system does your Blazer have? Does it have the 3 button selector (np-233 front diff) on the dash, or the 4 button (np-236 front diff) with auto-4wd?
Old Sep 24, 2018 | 11:25 AM
gman4q2's Avatar
I'm asking because yesterday I pulled out of my driveway and started driving and heard a lout bang. At first I thought I blew an air shock so I did a u-turn to get home to inspect.but they were fine. When it happened there was no shock shimmy shake or any change in anything. My second though was torsional stress in the transfer case and something that was supposed to be unlocked was actually locked and broke loose. Transmission seems to be fine. I jacked up the front end and the tires and axles turn free, so I assume if the transfer case was engaged, it's now free. If the Haynes manual is correct then I think my transfer case is the "NVG-236/246 NPS". here's a pic of the buttons;
Old Sep 25, 2018 | 06:23 AM
Strangerock's Avatar
Strangerock is on a distinguished road
if the vacuum to the solenoid on the firewall is backwards , the front diff will stay locked until the vacuum bleeds off,
m_coover99
Mar 17, 2018 11:05 PM
jmt1833
Mar 17, 2017 03:31 PM
fatalflaw888
Dec 13, 2016 06:33 AM
salloom
Jun 24, 2013 09:41 AM
bammontana
Feb 4, 2009 06:55 AM
