2WD Only Suspension Question
Old Mar 12, 2009 | 10:14 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default 2WD Only Suspension Question
My Blazer has the slot holes drilled for torsion bars. However they are not there, is there anyway i can purchase T-bars, and can i use it to lift my 4x2 a little bit? Since there are no cv's to stress out?
Old Mar 12, 2009 | 10:35 AM
Do not even consider gong to a torsion bar setup. There should be pre-runner style lifts available for a 2wd. You just have to find them. It will likely combine new control arms with longer springs and a new steering knuckle with a lift built into it. Probably will not be cheap, but...
Old Mar 12, 2009 | 11:06 AM
i saw a synergy Offroad kit 6in lift. I would want to lift my truck 5-6" with 33 or 35's. is this possible with 2wd
Why would there be torsion bar slot in the 2wd frame anyway?
Old Mar 12, 2009 | 07:10 PM
AJBert's Avatar
Much cheaper for GM to produce only 2 frames for the S series (ZR2 is a different from non-Z frames) than to produce 3 different frames.
Your best bet is to look into the pre-runner lifts.
Old Mar 13, 2009 | 09:02 AM
what are the pre-runner lifts?
hypertek
May 25, 2013 09:17 PM
jmac219
Aug 27, 2011 03:42 PM
calicojack
Suspension Tech
Oct 13, 2009 08:37 PM
1blkblazer422
Sep 26, 2009 12:44 PM
rooster
Jun 7, 2007 08:40 AM
