2wd Upper Control Arm Removal Issue
Old Sep 26, 2014 | 03:32 PM
BIGJEFF64's Avatar
BIGJEFF64 is on a distinguished road
Default 2wd Upper Control Arm Removal Issue
I have tried to remove the 2 bolts that hold the control arm assembly to the frame 2 separate times no i have soaked them in PB blaster, tried using a breaker bar and they will not budge!!! does anyone have any idea?? i dont have access to air tools unfortunately or i would have tried that. Ultimately i need to replace the upper and lower bushing so if someone has done this on a 2wd please tell me how to get this done. thanks
Old Sep 26, 2014 | 04:54 PM
chris015's Avatar
its fairly simple.the head of the bolts have a square flange on each one to keep them from backing out...
try removing from only the nut. if they wont buldge try some heat. hit up walmart etc for a yellow bottle of map gas. its hotter then propane,propane wont do it. get em hot,and go at it.
Old Sep 26, 2014 | 11:09 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
And keep the fire extinguisher handy. Heat and beat wins every time!
Old Sep 27, 2014 | 07:06 AM
BIGJEFF64's Avatar
I haven't tried heat so that's my next step thanks and do I need to do something with the flange or just work on the nuts with heat?
Old Sep 27, 2014 | 07:47 AM
05canjimmy's Avatar
05canjimmy is on a distinguished road
you have to get the nuts off. then you gotta beat those bolts trough the bushing
Old Sep 28, 2014 | 07:35 AM
BIGJEFF64's Avatar
The bushings are so bad I don't think that will be as much of a struggle. The real pain is gettin these off the truck then tryin not to bend the arms. I have read these aren't the strongest control arms out there
ryanleh
Sep 3, 2011 08:46 AM
nitro7
Apr 16, 2011 01:59 PM
cage47
Jun 11, 2010 12:17 PM
Marcin
Nov 11, 2006 10:03 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
