3 simple tech questions, please help!
Old Jan 24, 2012 | 10:35 AM
Gnfanatic's Avatar
Gnfanatic is on a distinguished road
Default 3 simple tech questions, please help!
Hey guys, My 4wd actuator is shot, np I am converting to mech setup. I have 3 simple questions, please help me out.
1-) Why was the actuator filled with tranny fluid?
2-) the small vac line that goes to the actuator, comes from behind the motor, near dist, where does it go to??? it needs replacement as well.
3-) there is a 4 pin (yellow connector) metal box under the truck, mounted to crossmember thats extremely corroded. I want to replace it but dont know what it is called and what it does??
thanks!!!!!
Old Jan 24, 2012 | 03:33 PM
Gnfanatic's Avatar
45 views and not a bit og help! cmon! ?
Old Jan 24, 2012 | 04:30 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Any pics??
Old Jan 24, 2012 | 10:04 PM
AJBert's Avatar
1) The acuator has tranny fluid in it because the transfer case switch, which sits on top of the transfer case has failed allowing transfer case fluid into your vaccuum system.
2) See answer above.
3) Not a clue, would need more info to help.
Being as you have fluid in your system now, you need to change out all of your vaccuum lines, check your HVAC controls and make sure there is no fluid in the cansister. If you don't do it now you will wish you had when everything starts to fail later.
Old Jan 24, 2012 | 10:06 PM
Gnfanatic's Avatar
Thank you sir! I noticed there are 2 different types of transfer switchs, 1 has 3 ports the other has 1 connector/? At least this is what rock auto is showing.
Old Jan 25, 2012 | 10:49 AM
spittybays
Guest
Posts: n/a
The $16.84 one.
Old Jan 25, 2012 | 10:57 AM
Gnfanatic's Avatar
thanks guys, I am picking it up tomorrow morning,. I would like to buy vac hose but dont know the size or different sizes there are without taking them all out. Is there a few diff sizes I can get several feet of while I am there??
thanks you again!!
Old Jan 25, 2012 | 11:13 AM
war00's Avatar
war00 is on a distinguished road
3) things with yellow connectors is related to air bags. if this is on the front cross member *****BE VERY CAREFUL WHAT YOUR DOING******** this is the air bag impact sensor. make sure you disconnect the battery for at least ten mins and pull the airbag fuse if equip.
Old Jan 25, 2012 | 01:48 PM
Gnfanatic's Avatar
I took a pic, its rotted bad, is it for the airbag???
Attached Thumbnails 3 simple tech questions, please help!-sensor.jpg   3 simple tech questions, please help!-sensor1.jpg
Old Jan 26, 2012 | 11:58 AM
war00's Avatar
yes i do believe that is for the air bag.
was it up behind the front bumper?
