4 wheel dig problem
Sounds like the typical front axle engagement issue...
There are three things that it could be.
A problem with:
A problem with:
- The front axle engagement vacuum system including, but not limited to:
- A faulty vacuum line from the engine to the vacuum reservoir.
- A faulty vacuum line from the engine vacuum system to the transfer case vacuum switch.
- A faulty vacuum line from the vacuum switch to the vacuum actuator.
- A faulty vacuum actuator.
- The front axle engagement cable from the vacuum actuator to the front axle.
- The front axle engagement collar/shift fork inside the front axle.
i am not sure what you call grinding. but my front diff made a clicking noise (like a playing card in bike spokes) under agressive 4wheeling and front tires stoped working. i was told i was losing vacume. so i bypassed vacume and pull cable manually and never had the problem since.
mirrorimij
Jun 8, 2019 03:34 PM
DetailersDomain
Detailing
Jan 21, 2011 07:09 PM
OuttaControlHPC
Mar 5, 2009 06:07 PM
