4 wheel drive diagnoses
Old Jan 8, 2018 | 06:20 PM
Tj89's Avatar
Tj89 is on a distinguished road
Default 4 wheel drive diagnoses
My 98 blazer will not go into 4hi or 4lo just blinks. So I replaced my transfer case switch, checked under the battery and the actuator pump seems to be in fine condition, everything appears to be hooked up just fine and no vacuum hoses are broken or leaking. Any ideas?
Old Jan 8, 2018 | 06:59 PM
Did you check the Transfer Case Control Module that resides in the passenger side kick-panel? Is the TCCM clicking? I had mine go out on me giving similar symptoms.
Do you have the 4-Button or 3-Button system?
Old Jan 8, 2018 | 07:01 PM
Tj89's Avatar
I have the three button system. I don’t believe it is clicking but definitely something I will look at any ideas help at this point. Thank you.
Old Jan 8, 2018 | 07:28 PM
There should be some clicking as I believe the TCCM has relays in it to direct power to different circuits.
Old Jan 8, 2018 | 07:52 PM
Strangerock's Avatar
Strangerock is on a distinguished road
you say the hoses and actuator look in good condition , but do you have vacuum to the actuator ?
mirrorimij
Jun 8, 2019 03:34 PM
Bob Z
Mar 20, 2017 12:58 PM
joejiz
Jun 23, 2016 05:27 PM
warthogdriver
Apr 2, 2012 01:26 PM
lizzj70
Jun 23, 2010 06:57 PM
