4 wheel drive mayhem 2000 blazer
Old Jul 24, 2012 | 04:35 PM
necropenetrator's Avatar
necropenetrator is an unknown quantity at this point
Default 4 wheel drive mayhem 2000 blazer
2000 blazer
3 button switch
loud bang when engaged in 4hi seems to slow the truck down considerably, only way to take out of 4 hi is to go in reverse, drive shaft from the transfer case to the front differential seemed to bash a hole in the bell housing where the universal joint is. i removed the transfer case vacuum switch and cleaned it to check for sticking, filled up the front differential which was low on gear oil.... still is screwed up. checked the vacuum actuator, it squats down when in 4hi and seems to be doing its job. big headache. if it needs professional work how much would it cost! thanks forum!
Old Jul 28, 2012 | 04:11 PM
PROBLEM fixed mismatched front tires.....sounds stupid but the spare was a little smaller and i didn't notice till i got close and read the numbers.
mirrorimij
Jun 8, 2019 03:34 PM
drnwoody
Jan 26, 2013 05:38 PM
laser770
Jan 21, 2013 01:36 AM
lizzj70
Jun 23, 2010 06:57 PM
BEAT MY JIMMY
Shows & Clubs
Apr 20, 2010 12:18 AM
