4wd to 2wd
Old Jan 28, 2009 | 09:42 PM
Sovannara's Avatar
Sovannara is an unknown quantity at this point
Default 4wd to 2wd
i was wondering since i'm never going to use 4wd is it possible to take it out?
problem is that my car keeps switching from 2wd into 4wd lo..without even pressing the button and i was wondering if i can take out the 4wd light indicator switch out... which i read from..http://www.carspace.com/guides/1996-...-Switch-Repair
2001 chevy trailblazer 4dr 4wd
Old Jan 28, 2009 | 09:49 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: 4wd to 2wd
If im wrong somone will correct me shortly but I would think the easiest way to do this (without tripping any service 4wd or ses lights) would be to just disconnect the vac line from the actuator and plug it (this stops it from engaging the front axle).
Old Jan 28, 2009 | 10:18 PM
WolfPack's Avatar
could just pull the fuse?
Disconnect the TCCM?
I wouldnt want a hole in my dash..
Old Jan 28, 2009 | 11:37 PM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Ya the fuse would most likely be the best way but im not to sure either. I wouldn't disconnect the vacuum from the actuator though since your truck is going to 4low. If you disconnected that it would still go into 4low it just wouldn't lock the front axle in. so you would really be in 2low.
Old Jan 29, 2009 | 07:29 AM
Just leave the system there and periodically use it so if you end up selling the truck, everything still works as it should. An unused 4wd system will eventually stop working.
If you do not use 4wd for anything, you may want to consider purchasing a 2wd vehicle and selling the 4wd one rather than devalue what you have...
Old Jan 29, 2009 | 09:59 AM
bandidolenny's Avatar
You want to make a 4x4 into a 2wd?... its usually the other way around. Yea I agree that you should look into trading towards a 2wd. Then you dont have to worry about doing maintenance on the 4wd system.
Old Feb 4, 2009 | 09:03 PM
Sovannara's Avatar
i still have a problem wit the car.. okay this happened to me before. 2wd has a solid light and a blinking 4wd lo light... WHICH i have never touched or pressed.. once i put it in reverse to come out of my driveway then i move it from reverse to drive it tends to switch in between automatically.. so then the car feels very jumpy n i sometimes cant get it outta the 4wd lo... so what should i do.. mom doesn't want me to sell the car.. im only 19
Old Feb 5, 2009 | 08:17 AM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Have you tried searching the forums? I believe I have seen this problem before, better to fix it then disconnect the system, one day you will curse when you actually need it.
swartlkk
Feb 6, 2025 09:57 PM
theclothedcreature
Lifting Tech
Jan 22, 2010 01:37 PM
jack
Aug 5, 2006 10:59 AM
fenderfree
Dec 14, 2005 09:04 PM
zero psi
Tires and Wheels
Apr 22, 2005 11:54 PM
