4wd actuator
Old Jan 31, 2011 | 08:55 AM
Aanenson's Avatar
Aanenson is on a distinguished road
would i be able to manually activate the tranfer case? i dont really wanna spend the money to fix the tccm again..
thanks
Old Jan 31, 2011 | 09:13 AM
There is a lot of stuff going on with the NV236 transfer case which makes it very difficult to manually actuate.
Old Jan 31, 2011 | 10:23 AM
UberFail's Avatar
UberFail is on a distinguished road
not 100% sure if the setup is anything identical for what the actuator does on your 4x4 but mine is stuck "open" because the vacuum switch is toast & i'm not able to engage 4x4 on er. also read somewhere else that its preventing me from actually being able to engage it.
Old Jan 31, 2011 | 08:47 PM
Aanenson's Avatar
thanks guys! ill try and get er done! hopefully this week cause of all the snow!!! haha
Old Mar 23, 2011 | 06:58 PM
Aanenson's Avatar
ok found out its most likely the switch for the 4wd and now i got another problem....its misfiring, the code is saying its running lean on both banks, replaced the injectors and both o2 sensors, had a tune up about a month before that, one of my classmates said it could be the MAF sensor.
Old Mar 24, 2011 | 01:21 PM
blazinloud's Avatar
those are easy to clean, use electrical contact cleaner, and not brake/carb cleaner
Old Mar 26, 2011 | 04:54 PM
Mickenblazer's Avatar
Mickenblazer is on a distinguished road
I have a 93 s10 4x4 4.3 v6 and I was needing to know how to manually lock my 4x4 in(broken vacuum line). And I have a lever on my floor for my 4x4
Old Apr 17, 2011 | 12:00 PM
Aanenson's Avatar
ok im back, switch is good and tccm is good, so now im guessing its the harness, how hard will it be to replace that?
Old Apr 17, 2011 | 02:44 PM
Electrical harness? Have you ohm'd out the wiring and/or inspected the connections to make sure that is what you actually need?
Old Apr 18, 2011 | 09:33 AM
Aanenson's Avatar
yes i believe it has been checked but i can do it myself, it went into 4wd all by itself once and the buttons would not respond, so i got new buttons, still nothing, so i took the fuse out.
