4WD button Need help!!
Old Oct 3, 2013 | 04:42 PM
Renegade7369's Avatar
Renegade7369 is on a distinguished road
so are the brown and purple wires that are exposed supposed to be plugged in to the 4pin connector instead of the 4 grey wires?
Old Oct 3, 2013 | 04:43 PM
coolasice's Avatar
coolasice will become famous soon enough
check your glove compartment for rpo code starting with np_ more then likely has NP1
Old Oct 3, 2013 | 04:44 PM
if it is np1 do i need to get the 3 button switch?
coolasice's Avatar
yes, you do
Old Oct 3, 2013 | 04:46 PM
coolasice's Avatar
the wiring is the same for the 3-button but ignore the neutral indicator as there is none for the 3-button, just use the two center wires
if i get the other switch what do i have to do to get it wired up right? do you have a good wiring diagram i can use or something?
Old Oct 3, 2013 | 04:48 PM
coolasice's Avatar
just need to use the two center wires as i said earlier, (those wires are just for lighting the backlight and leds)
Old Oct 3, 2013 | 04:50 PM
I need to pin the brown and purple wires into the bottom 4pin connector?
Old Oct 3, 2013 | 04:52 PM
coolasice's Avatar
yea, you do
Old Oct 3, 2013 | 04:54 PM
ok awesome. After that should everything work right? the guy i bought it from said everything was working fine until the switch got stolen out of it. So im assuming he couldnt get the switch to work because he had the wrong switch... so if he is right i would assume everything would work fine if i get the 3 button switch...
