4wd help
Old Jul 21, 2015 | 11:09 AM
gunner338's Avatar
gunner338 is on a distinguished road
Exclamation 4wd help
Ive read through multiple articles about 4wd not working, and haven't really came across my issue yet, so here is the rundown. I have a 00' ZR2. I was out wheeling last night and attempted to switch to 4 high. Not only would the button not work, but the truck decided to switch itself to 4 low instead. I couldn't put it back to 2 high, but I could switch to "auto 4wd". The 2 high and 4 high buttons do not work. I unplugged the battery and it went back to 2 high, but the same issue with the buttons is happening. I checked all the vacuum lines and hoses, and replaced a decent section of damaged line, with no change. What other issues could I be looking at?
Old Jul 21, 2015 | 11:30 AM
Common problem is corrosion on the connector at the TCCM. If the corrosion is between the two pins that lead up to the dash switch, it can throw off the resistance of the circuit and cause it to switch mode/range at random. The Tech Article on the NV236 transfer case runs through this as well as the expected resistance values for the switch that can be easily tested with a DMM at the TCCM connection.
Old Jul 21, 2015 | 11:44 AM
gunner338's Avatar
So I should check for corrosion at the tccm first?
Old Jul 22, 2015 | 10:02 AM
LesMyer's Avatar
Yes, and you can also check the resistance through the control switch at the TCCM when different buttons are pushed. This will require you to read and understand the schematics for those circuits.
Here is the link:
https://blazerforum.com/forum/tech-a...rmation-41198/
Old Aug 24, 2015 | 11:40 PM
filtalr's Avatar
filtalr is an unknown quantity at this point
Just wondering if you ever found a solution. Mine is doing somewhat the about same thing. Started in 4wd low one day .. then it was stuck in 4 auto .. and had to reset TCCM to get it back into 2 hi. Hope it stays there long enough for me to find what's wrong. Pulled the TCCM and checked connectors. Checked vacuum actuator is holding vacuum and cable travel is good. Got fluid ordered -- hope it keeps working until it comes so I can change it -- sorely overdue for a fluid change...
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
