4wd I'm abut to give up
Old Oct 26, 2013 | 09:00 AM
Doug Fields's Avatar
Doug Fields is on a distinguished road
Default 4wd I'm abut to give up
Well I've replaced the actuator, cable , and vacuum switch. Still not engaging the actuator. I know it's prolly the vacuum system but I don't know where to start.
Old Oct 26, 2013 | 09:03 AM
newguy's Avatar
did you find any trans fluid in your vacuum lines
Old Oct 26, 2013 | 09:09 AM
I did and I blew them out
Old Oct 26, 2013 | 12:05 PM
newguy's Avatar
do you hear the transfer case engage when you push the 4 wheel button? if so you may have a leak in the line going to the actuator
Old Oct 26, 2013 | 02:20 PM
robsteez's Avatar
robsteez is on a distinguished road
I know the feeling, the 4 wheel drive system on these trucks are so finiky. After about 6 months of trying to figuer out what was wrong with mine it was 3 different problems. 1 my vaccum hose was disconnected from my actuator, 2 my vaccum switch on the tcase was seized, i then replaced the push buttom 4x4 switch and the mccm 4x4 computer thing. Then i gave up for a few month's until winter came then out of no where I started slamming a hammer on the Encoder motor on the tcase then it started working. It must of been seized up or something and hasn't failed me now in over a year and a half.
Old Oct 26, 2013 | 07:22 PM
LannyL81's Avatar
If you have ATF in any vacuum line, then a vacuum switch on the T-case is bad and need replacement.
Check for vacuum at the actuator under the battery. If not, then just follow the line. It goes to the vacuum switch. Check for vacuum here. If not, continue following the line.
Next stop is a T fitting. Check for vacuum on these....and so on. Vacuum source is the engine.
Vacuum also goes to the T-case switch.
The likely problem is a rotten vacuum line. Plan on replacing all of them.
Old Oct 28, 2013 | 07:33 AM
Thanks. I'm just gonna run new lines.
Old Oct 28, 2013 | 07:47 AM
newguy's Avatar
Good luck hope this is it. Can be a PIA
Old Oct 29, 2013 | 07:12 AM
What is a PIA?
Old Oct 29, 2013 | 07:48 AM
newguy's Avatar
Pain in the ***
