4wd indicator light goes out under acceleration
Old Dec 8, 2013 | 07:19 PM
warrenandress's Avatar
warrenandress is on a distinguished road
Originally Posted by stoy75
I have a 1995 chevy blazer two door with a manual transfer case. Through due diligence and repairing I have installed a new vacuum actuator, a new transfer case shift cable, and a new vacuum switch. Everything seemed cool until it snowed last weekend. Four wheel drive seems to be working at low speed as I tried to make a tight turn to test it and it tightened up. But when driving under acceleration the lights on the front wheel indicator go out. Let off the gas and they come back on. Any ideas. Hopefully I gave you enough info.
motor mount or trans mount bad
Old Dec 8, 2013 | 07:31 PM
Post
or to many miles on motor losing vac check with vac gaug and giv it gas
Old Dec 9, 2013 | 12:31 PM
stoy75's Avatar
stoy75 is on a distinguished road
Where would that be lost at?
Old Dec 9, 2013 | 03:52 PM
....But when driving under acceleration the lights on the front wheel indicator go out. Let off the gas and they come back on. Any ideas. Hopefully I gave you enough info.
If the engine runs well, this indicates there is sufficient vacuum. Did you test the vacuum check valve? Did you check the vacuum lines at the vacuum switch yet? Check each line separately and make sure it holds vacuum, and that they are not restricted. You'll need a hand vacuum pump and a vacuum gage to check them. Or you can replace them, (one at a time) to make sure they are connected properly.
tdbone1
Dec 20, 2012 09:40 AM
mxzretta
Nov 23, 2010 10:42 PM
hotrodsbyg
Jul 3, 2010 02:37 PM
dolphin1
Nov 8, 2009 07:24 PM
naf821
Aug 8, 2007 07:19 AM
