4WD Not Working....
Old Jul 17, 2009 | 05:48 PM
Drivin_Foxfire's Avatar
Drivin_Foxfire is on a distinguished road
Question 4WD Not Working....
I was given a 1998 Blazer from a charitable organization with only 63K on it. All I was told was that the 4WD did not work and to keep it at 2HI. It came with 4 snow tires. How does that problem effect the rest of the system? What do I need to look out for?
Old Jul 17, 2009 | 10:45 PM
LAWDOG's Avatar
LAWDOG is an unknown quantity at this point
With rear wheel drive, the rear end will be all over the place in winter. You will need to adjust your driving habits. Also are the orange lights on the 4x4 switches on? Not sure about the 98 but, my 01 will sometimes not change from 2 to 4 wheel drive because of a loose connection at the switch.
Old Jul 21, 2009 | 01:50 PM
jswavely2916's Avatar
jswavely2916 is an unknown quantity at this point
Where is the switch?
Old Nov 20, 2009 | 06:34 PM
old skool luvr's Avatar
i know this is old, but did you get this fixed? it's good to keep everyone informed with the results of your problems.
also,
she said the truck has snow's all the way around, what the hell does that have to do with her question?
my 4WD wasn't working when i first bought it last December, and it worked fine in the snow, and we can get some crazy snow up here!
Old Mar 12, 2010 | 02:51 PM
Just found out this is "one of this vehicle weaknesses" what else do I have to look forward to????
Old Mar 12, 2010 | 08:07 PM
We can help you get it fixed properly, but we need a bit more information.
The 4wd switch on the dash will be to the left of the center dash vents (above the radio). If you have the 3-button switch (2HI, 4HI, & 4LO), then you have the NV233 transfer case. If you have the 4-button switch (Auto4wd, 4HI, 2HI, & 4LO), then you have the NV236 transfer case. Take a look at the Tech Article (DIY) Index link in my signature for 4wd related posts to do some reading up on what to check and how.
Old Mar 12, 2010 | 11:30 PM
"If you have the 3-button switch (2HI, 4HI, & 4LO), then you have the NV233 transfer case."
Yep... this for sure... from memory
Old Mar 13, 2010 | 01:17 AM
chevy-nutty777's Avatar
chevy-nutty777 is on a distinguished road
Default 4wd not working
you have a switch on front differential may need replacing also there is a vaccum acuator under battery also may need replacing
Old Mar 13, 2010 | 11:19 PM
like Kyle said, we need more info from her before we can point her in the proper direction.
other wise we could just make out a long list for her to start checking anything & everyting related to the 4WD system.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
218persuader
Aug 20, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
LYK2ROC
Dec 5, 2008 07:08 PM
