4wd partially engaging. Help!
Old Feb 29, 2012 | 10:03 AM
02fbody35th's Avatar
02fbody35th is on a distinguished road
Default 4wd partially engaging. Help!
So I'm getting a whining noise at 30 mph and up from the front diff area when in 2wd. The noise completely disappears when in 4hi. So after some research I thought it could be the vacuum switch on the t-case so I replaced that with an ac delco unit. Problem still there. I checked for vacuum leaks and couldn't find any. The front diff is full of fluid and the 4x4 works fine when engaged. So what the heck is going on. Please help if you have any ideas. Thanks
Old Feb 29, 2012 | 12:29 PM
Tech Article (DIY) Index to the rescue:
4wd Front Axle Clicking When in 2HI - Goes Away when in 4HI/4LO
Old Feb 29, 2012 | 01:14 PM
Huh, very interesting and helpful. Thank you. So I have the three button case. And the problem sometimes goes away if I switch to 4 hi the back to 2 wd. But not always. And I already changed the t-case switch. So I'm thinking it may be a binding cable. Does that sound right to you?
Old Mar 3, 2012 | 06:23 PM
Ok so I replaced the t-case switch and that did nothing. So I was thinking maybe the cable I frozen. So I took the battery out to check that an everything seemed ok. N
But I pulled it out to lube it anyways. While it was out I decided to check to make sure the shift fork was pulling back in place. That was fine. I pulled it out and the springs pulled it right back. So I lubed the cable put it in and went for a drive. It was still humming in 2wd but not 4hi. Omg I'm so upset I can't figure this out. Swartlkk you seem like a knowledgable guy. If you can think of anything else please help. Thanks
seriosbrad
Nov 7, 2015 09:08 PM
Doverman454
Nov 29, 2008 01:45 PM
pacevette78
Nov 12, 2008 03:13 PM
zombiebebop
Engine & Internal
Dec 8, 2006 03:15 PM
Jeremy_87_S10
May 22, 2006 10:16 PM
