4wd question
Old Oct 29, 2013 | 12:25 AM
chitown906's Avatar
chitown906 is on a distinguished road
Default 4wd question
In my 03 my 4wd won't engage ,i don't hear the transfer case what so ever, and the light on the dash just blinks near the 4hi button , even while in neutral. What are some places I should start to try to diagnose this ? And, I have noticed the front end has a slight hum to it both front axles are good, axles seals have been replaced, wheel bearings are good as well no movement what so ever . I haven't owned a blazer prior to this so the slight notice from the front end almost like a hum so to speak .
Thoughts?
Chi_Town
Old Oct 29, 2013 | 05:52 AM
richphotos's Avatar
*Moved to Steering, Suspension and Drivetrain*
Old Oct 29, 2013 | 09:31 AM
El_Beautor's Avatar
First question to help us help you: Do you have the 3 button 4wd system or the 4 button with autotrac?
The first thing I'd check is if the actuator under the battery tray is getting vacuum when you push the 4wd button. It should be sucking down and pulling on the cable to the front diff. The actuator rubber boot can get cracked or torn and will leak.
Old Oct 29, 2013 | 11:49 AM
chitown906's Avatar
It has the 4 button autotrack to the left and 2HI,4HI,4LOW on the right .
Chi_Town
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
