4WD Vacuum actuator switch replacement?
Old Feb 6, 2018 | 12:54 PM
jflynn0322's Avatar
jflynn0322 is on a distinguished road
Default 4WD Vacuum actuator switch replacement?
96 blazer 4dr ls. In the recent snow i've noticed that my 4wd doesn't work. The light comes on on the button, i can hear it engage in the transfer case, but the tires don't spin. After investigating i saw my vacuum actuator switch under my battery tray is completely ripped. Instead of spending the (around) 50 bucks for a brand new replacement right now, is this a part that i can get off a blazer from a junkyard temporarily, or is it a part that i NEED to buy brand new?
Old Feb 6, 2018 | 01:02 PM
rockp2's Avatar
The chances of you finding a vacuum actuator that is in acceptable condition are probably pretty slim I would think. Unless maybe you found one that had been recently wrecked and has an actuator that had already bee replaced. I could be of course wrong, but buying new would be the way I would go in your shoes. If I remember correctly they don't cost all that much at all. And there's the whole "suck" issue of a used one failing on you when you need your 4wd the most.
Old Feb 8, 2018 | 10:25 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Just pull the cable out and clamp it with a small pair of vice grips. Been there done it. The front diff will always be engaged but no big deal. Astro vans and Bravada's were built that way. A lot of guys replace the passenger side of the diff with parts from a Bravada and drive them like that all the time. There is no load on the differential when in 2wd. If it bothers you come spring release the vise grips.
In the mean time plug that hose. You have a vacuum leak anytime the transfer case is in 4wd. Which isn't good for the engine.
50Chevy
Jan 5, 2013 04:44 PM
PaulO2288
May 21, 2011 05:31 AM
ford3517
Nov 10, 2009 05:39 PM
watsonracingteam
Aug 25, 2008 04:48 PM
rooster
Feb 18, 2007 07:16 PM
