4x4 Issue Can't track down
Old Oct 29, 2009 | 09:25 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
Exclamation 4x4 Issue Can't track down
Alright so heres my dilemma. I do not have 4 wheel drive and I have been troubleshooting for almost a year now. The actuator under the battery box is new, the switch on the t case is new, I have visually checked the vacuum lines and no leaks, I've checked the switch on the front diff and I made sure the cable was not broken. I'm probably missing something else but when I push 4wd, yes it’s an electronic 3 button, and it engages the t case. The half shaft locks but the front end won’t lock. Now I've taken it apart and pulled on the cable before and it locked just fine. I am almost leaning towards a cable and getting rid of the vacuum but I do not have the money right now and it would almost be silly seeing I’ve replaced so many vacuum parts.
Could someone please give me a few tips and point me in the right direction. Thank you guys.
Old Oct 29, 2009 | 10:08 PM
abig84's Avatar
just start bypassing stuff. run direct vacuum to the actuator to see if the switch is bad. or try manually squeezing the actuator to see if it locks the front axle to see if that is bad.
i got sick of mine going bad, i used to just manually pull mine and put a pair of vise grips on it
Old Oct 30, 2009 | 12:22 AM
ABN31B's Avatar
Originally Posted by Brianator99
leaning towards a cable but I do not have the money right now
you dont have $25 bucks and a free saturday? If you DO go that route, you can always ebay off the electronic/vacuum stuff you no longer need. recoup some of the losses.
Old Nov 1, 2009 | 09:17 AM
Okay ill try to track it down. It does lock up whien I pull it manually abig84. And ABN31B ive read that diy and I was thinking about going the route of a acutal kit if i did because no offense to that person but its not that clean.
KRUSHER
May 24, 2011 07:17 AM
02 Vortech
Street N Strip
May 17, 2006 08:45 PM
Likwid
Tires and Wheels
Apr 3, 2006 03:50 PM
Mar 22, 2006 02:21 AM
XtremeYellowChvy
Nov 15, 2005 03:01 AM
