4x4 not working right
Old Dec 22, 2010 | 09:16 PM
spmeyer76's Avatar
spmeyer76 is on a distinguished road
Default 4x4 not working right
I have a 94 Blazer, 193,000 on it.... New poster long time reader. I have an issue which I seeposted alot. My 4x4 will work when I disconnect the battery and reset the system. It will work fine while inthe driveway but once I leave and come back no 4x4 hi just low. I have replaced the vacumm lines, vacumm switch under the battey, the transfer case switch and now the motor. Same thing, will go into 4x4 low but no hi, messed with it now it is stuck in hi, I thought the moter was the issue but nope.... Any ideas? Maybe the switch is crapping out half the time? I re greased the cable and the front end is locked in 100%
Thanks Steve
Old Dec 22, 2010 | 10:01 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
Have you tried to pull codes from the TCCM? IT could be the switch like you stated but it could also be the TCCM. IF you haven't pulled the codes (if there are any), that would be the next step considering everything else you have done
Old Dec 23, 2010 | 07:09 AM
spmeyer76's Avatar
I looked for codes and all I had was a code for the EGR, which I cleared with the techII.
Old Dec 23, 2010 | 08:10 AM
This thread covers the reading of codes for the NV233 TCCM:
NV233 transfer case / encoding motor switch
And this thread covers the no mode switch (2HI to 4HI) for the NV233:
NV233 No Mode Switch (ie. 2HI to 4HI)
Wire colors and pin-outs may be different, but it should help.
Old Dec 23, 2010 | 08:21 AM
Tinted's Avatar
Tinted is on a distinguished road
bad dash switch ot tccm
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
ryankinder82
25
Feb 18, 2013 11:02 AM
BluBlazin
Oct 12, 2009 11:38 PM
redpeppers
Apr 7, 2007 04:55 AM
