4x4 problems
Old Jan 27, 2015 | 07:36 PM
dedub2104's Avatar
dedub2104 is on a distinguished road
Default 4x4 problems
I have a 99 s10 zr2 that wont go into 4hi it will go into 4lo and 2hi but not 4hi. When i push the 4 hi button it does absolutely nothing. And when i put in N and push 4lo it engages but the 4hi and 4lo lights are on. Somebody please help
Old Jan 28, 2015 | 07:55 AM
Jamaroon's Avatar
check the connection at the tccm for corrosion. its under the passenger side kick panel.
Old Jan 29, 2015 | 07:07 AM
dedub2104's Avatar
I checked all connections they seem to be good any other suggestions. Thank you
Old Jan 29, 2015 | 07:57 AM
Jamaroon's Avatar
I'd check to see if you can manually put it into all positions to make sure there's nothing binding in the transfer case. I doubt this would be the case though since it goes into 4 lo fine but it's good to check anyway.
My next thought is it is the TCCM itself
Old Jan 30, 2015 | 05:22 PM
dedub2104's Avatar
Whats the name of the rod that goes into transfer case that engages the hi and low 4x4
Old Apr 4, 2015 | 06:10 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
encoder motor?
Old Aug 26, 2015 | 05:10 PM
AleroBlazer's Avatar
AleroBlazer is on a distinguished road
Hey, sorry to bring a tread back from the dead. ( didn't want to start a new one. ) but did you ever find out what the issue was? i'm having the same problem and been searching on here for awhile, but can't figure it out myself. Thanks if anyone figured it out.
Old Sep 4, 2015 | 01:32 PM
gothicsera's Avatar
gothicsera is on a distinguished road
I had a similar issue with mine and it was a fault with the switch in the dash. I removed the switch, took it apart and found that a number of the solder joints on the board for the main connectors had cracked.
I re-soldered all of the the joints and it's worked perfectly ever since...
SJ
notrealimportant
Jul 15, 2011 01:29 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
chevblazer02
Oct 15, 2006 03:03 PM
vtlew
Jun 23, 2006 09:13 PM
