4x4 stuck in 4hi
Old Nov 1, 2009 | 07:33 PM
blackjimmy's Avatar
blackjimmy is on a distinguished road
Default 4x4 stuck in 4hi
Hi guys. i have a 98 blazer 3 button(233 i believe) it is stuck in 4 hi, 4 low also works. but when i try to shift to 2 hi .it just blinks, and then goes back to 4hi. i,m lost. any suggestion on the cause?
Old Nov 1, 2009 | 07:49 PM
Could be many different things. The NV233 transfer case has been discussed many times. Check out the Tech Article (DIY) section for a post entitled OBD2 Non-Automatic Transfer Case Diagnosis (or something to that effect) for a way to check the codes. Then search on NV233 and read up.
Old Nov 1, 2009 | 08:34 PM
stevo's Avatar
stevo is an unknown quantity at this point
idk if this would be it or not, but the vacume actuator goes bad sometimes
i would do this if it did turn bad
https://blazerforum.com/forum/showth...916#post259916
Old Nov 1, 2009 | 08:48 PM
blackjimmy's Avatar
i,ll check it out .thanks
Old Nov 3, 2009 | 07:27 PM
blackjimmy's Avatar
Found a bad switch on transfer case.replaced it,axle dissengages.I got in 2 hi but light is not on & cannot get to 4 hi. Do you think my shift motor is bad or my tccm? I dont get any codes but i had the battery off when checking the diaphragm (it works fine).I,m lost, i here the transfer case making noise while trying to shift.
Old Nov 3, 2009 | 07:33 PM
codes?
Old Nov 3, 2009 | 07:35 PM
blackjimmy's Avatar
i shorted pin 13 but it just flased once . i think i lost them when battry was taken out to check the diaphragm.
sorry for the spelling i just noticed when i refreshed
Old Nov 3, 2009 | 07:45 PM
Try shifting it a few times to other modes to see if it will set the codes again. You can also test the switch. The wiring diagrams for the NV233 are around here somewhere. Maybe check out the thread by error_401 in the Tech Article (DIY) section. I think I posted the wiring diagrams in that thread.
Old Nov 3, 2009 | 07:53 PM
blackjimmy's Avatar
Thanks i,ll try tommorow its getting late and cold .let you know if i get any.
I should tell you also that over the last year or so ,while driving on the highway it would ocassionally try to shift into 4hi ,i would hit the 2hi button and it would go back to normal. its my wifes truck so i didnt realize what it was doing for a long time (she sometimes exaggerates on stuff) ,until i was with her when it did it.and it started to stay in 4hi in the last couple of weeks.i dont know if this helps but i will try for the codes again tomorrow.
Old Nov 4, 2009 | 05:46 PM
blackjimmy's Avatar
still no codes.i,m lost
jeffrozar
Nov 4, 2011 10:08 AM
hammer051
Jun 4, 2011 10:25 PM
ryndraeger
Nov 21, 2009 05:15 PM
Alterac
Aug 25, 2008 08:48 PM
cubontheridge
Apr 20, 2008 06:58 PM
