4x4 vacuum pressure?
Old Nov 4, 2008 | 03:14 PM
Default RE: 4x4 vacuum pressure?
I believe it was only in the 98+ trucks.
Old Nov 4, 2008 | 03:17 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
ORIGINAL: swartlkk
Is that why you brought it up...since he has a 94? heehee [sm=rolleyes.gif]
Old Nov 4, 2008 | 03:21 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
ORIGINAL: mysons95
ORIGINAL: swartlkk
I think he was referring to my 2001, we discussed its Auto in another thread.
Old Nov 4, 2008 | 03:22 PM
While the OP has a 94, abadinalbany does not. I was responding to that.
mysons95's Avatar
ORIGINAL: abadinalbany
ORIGINAL: mysons95
ORIGINAL: swartlkk
Oh, OK. I didn't know about the other thread.
Old Nov 4, 2008 | 06:25 PM
bman192000's Avatar
bman192000 is an unknown quantity at this point
doesn't seem to be frozen. it moves so i may have a cracked line , damned if i could find which one though. if i get it found i'll let you know. otherwise i might have to try that cable lock. thanks
ORIGINAL: swartlkk
Should be somewhere close to engine manifold vacuum pressure. If it is low, then you have a cracked line somewhere.
It is also possible that the cable itself has started to freeze up a bit. You may need to lubricate it.
Old Nov 4, 2008 | 09:09 PM
ORIGINAL: bman192000
just replace 'em all. vac line is cheap.
Old Nov 5, 2008 | 06:05 PM
mysons95's Avatar
Good point. Replace all the vac lines.
Then...replace your vacuum actuator.
Old Nov 11, 2008 | 07:39 PM
bman192000's Avatar
Ok I've just taken the battery tray out again and then ran the truck up on 4 jack stands. When I turn on the 4 wheel drive the actuator sucks down all the way and pulls the cable a good half inch, i can't make it pull back and further by hand, and the front wheels still won't move. If the vacuum is strong and moving the actuator like it's supposed to and the transfer case is locking up what else can it be?
Old Nov 11, 2008 | 07:52 PM
It is quite possible that something inside the front axle is busted. When you put it in drive with the truck up on jack stands and in 4wd, does the front axle spin? If not, then it is something in the transfer case not getting into the appropriate mode.
