4X4 wont engage at all.
Old Jan 24, 2012 | 12:32 AM
KirovRussian's Avatar
KirovRussian is on a distinguished road
Default 4X4 wont engage at all.
I can push the buttons and the lights come on and i hear the solenoid try to put it in four wheel but with some testing, blazer wont even go into four wheel drive at all. any ideas??
Old Jan 24, 2012 | 09:25 AM
Tinted's Avatar
Tinted is on a distinguished road
what year blazer? how many buttons?
Old Jan 25, 2012 | 02:04 PM
Default blazer
its a 1995 blazer with 3 buttons, 2 wheel drive, 4 high, 4 low
Old Jan 25, 2012 | 08:48 PM
Dave43609's Avatar
Dave43609 is on a distinguished road
i have a 98 blazer, had the same troubble. push the button and could hear it click like it was locking in. i found a hole in the vacume line from where it had been rubbing on the intake. that would be the first thing i would check.
Old Jan 29, 2012 | 01:23 AM
Kyle Wood's Avatar
Kyle Wood is on a distinguished road
I have a 98 blazer and it wouldn't engage turned out it was the fuse ! Start there !
Old Jan 29, 2012 | 07:04 AM
sas10blazer's Avatar
sas10blazer is on a distinguished road
I had the same problem I had a bad encoder motor and bad tccm. I swaped to a manual shifted 3 button case and used a clamp to actuate the plunger on the front diff.
Old Jan 29, 2012 | 01:02 PM
jmessic's Avatar
jmessic is on a distinguished road
Default notorious
ya i had the same problem with my blazer and looked online and basically do as the previous post said and check your fuses and your lines and the problem i found was the 4x4 accuator(i think thats what its called). its under the battery on my 02 zr2, the rubber/foam boot that holds vaccuum to the lines was busted and rotted away. i picked up a new one from auto zone for like $8. replaced and next time i pushed the button it lit up and engaged. hope this helps
Old Jan 29, 2012 | 04:26 PM
choover82's Avatar
choover82 is on a distinguished road
ive got a 92. Ive changed the 4x4 actuator, vacuum switch, check for vacuum leaks, found none...have vacuum to the switch, and can hear the encoder motor....err...it makes the sound of it trying to engage but i havent felt any front wheel engagement.
also did the code check....
I have a code 2 but i hear the encoder motor working....do i just needed to reset it?
Old Jan 29, 2012 | 04:28 PM
choover82's Avatar
I doubt this...as my 4x4 actuator cost me $50 (new)
Old Jan 29, 2012 | 05:30 PM
Kyle Wood's Avatar
yea like i said mine i would hear click go off real quick, took it to a garage turned out it was the 4x4 fuse, try it cheap fix
