74 K5 loose steering and wobbly steering wheel
so now that i have most of the engine work done im moving on to other things like the steering. the truck has a lot of play in the steering wheel. for one, i can move the steering wheel around in all directions. it is an adjustable one and that does still move it up and down but after it locks into place it moves all around in all directions.
and when im driving it it has a lot of play in the wheel before i can start turning the thing. im thinking it needs new pitman arms or something like that? it has a new steering stabalizer on it right now and some of the bushings up front are new. so its not all that bad. i think most of the stuff on this is original lol . |
if your tilt is loose you can google loose chevy steering column and find all sorts of stuff on it. its happened to like every other chevy i owned. its just a matter of taking apart the column and tightening some screws.
as for the steering itself play. best way to find out is have someone sit in the truck and move the wheel back and forth and you lay under the truck and see whats bouncing around under there |
thanks bud. i figured if i google searched it would bring up this site right back to some not related topic. but ill give it a shot. thank god i dont need a new steering column.
Originally Posted by litterbug
(Post 467675)
that would suck. i know its probably been like this for a while cause the column feels like its not even bolted to the dash anymore. (yes i checked that it is bolted to the dash)
