95 4wd blazer
Old 07-04-2009, 02:51 PM
rdbtoasta's Avatar
rdbtoasta is on a distinguished road
Default 95 4wd blazer
I have a 95 blazer 4wd and for starters i love it! But the shocks are so bad its like they don't even exist. I purchased some new ones from the local parts store for around 32 bucks a pop. I purchased the blazer from someone that just moved from up north and there is a good bit of rust underneath. I managed to get the top bolts off, but can only get the bottom nut off, not the bolt. Ive hammered till i am blue in the face and i cant get it out. I took a grinder to the outside sleeve of the shock and there is a sleeve that the bolt is going threw. When i put the socket to it both the sleeve and the bolt turn at the same time.
Has anyone seen this before? Should i just cut the whole thing off and replace the bolt, if so, where is the best place to find one?
Thanks!
Old 07-04-2009, 02:57 PM
bandidolenny's Avatar
Just grind/cut the old bolts out. Any auto parts store should be able to see you new bolts.
Old 07-04-2009, 03:19 PM
rdbtoasta's Avatar
Thanks, i just wasn't sure if there was a tool i was missing or some trick. This is my first blazer. I do find it odd though that this blazer doesn't have coil springs. A buddy if mine has the same year explorer 4wd and it has them. As a matter of fact, most 4wd's that i have seen do.
Thanks again!
Old 07-05-2009, 03:17 PM
Rust can be a pain. Just cut it off and get some new hardware and save your time and aggravation.
Old 07-06-2009, 02:25 PM
rdbtoasta's Avatar
Thanks, yeah, that's exactly what i did. All is well with shocks now.
Geir
10-09-2011 08:51 PM
ttwo
10-28-2010 12:35 PM
2001 ZR2
01-16-2010 12:39 PM
aspenrebel
12-12-2007 05:52 PM
Mikes1Addiction
01-12-2007 02:08 PM
Quick Reply: 95 4wd blazer
