95 Blazer alignment help!!!!
Old Sep 1, 2010 | 07:52 PM
kickme005's Avatar
Banned
kickme005 is on a distinguished road
Default 95 Blazer alignment help!!!!
95 blazer 4wd 4door. front tires was wear more in the inside of tire than the outside and noticed the steering wheel when i held it straight it went to the rite. had it aligned still went right. i put the uneven tires on the back and the back tires in the front. still goes right. had shop put 2 new tires on the front and got rid of the uneven tires. still went right. went back to the shop. they said it was in line. got mad and got my money back. went to tires plus and had it aligned and a little later still felt it went right went back they said they swaped froont tires side to side and it was fixed probly went right cuz road crown but i drove on old new even and uneven road. and been on brand new just paved flat roads but still goes right. just changed front brakes. whats wrong? friend and other people have driven and says my alignment is still off. also tires plus said alignment was not in specs from the other shop. said it was aligned after they did alignment.
Old Sep 1, 2010 | 08:10 PM
Sounds like your truck doesn't like you...
You likely have something worn in the steering/suspension that is causing the problems, but one of those shops should have caught the problem if they were worth anything.
Old Sep 4, 2010 | 12:46 AM
Leearchibald's Avatar
Leearchibald is on a distinguished road
Have you tried wheel bearings sometimes they make a pull,dragging brake and i know you changed the front tires but there is still the back ones and then there is caster...have a good alignment shop,someone that is the best check the caster,because if the caster is high on one side and low on the the other a vehicle will pull to the leading wheel!!!!
Old Sep 4, 2010 | 06:27 AM
kickme005's Avatar
Banned
tires plus said everything was inline
Old Sep 4, 2010 | 08:24 PM
croozer's Avatar
croozer is on a distinguished road
The tire places should have found any bad suspension parts. You can check your balljoints by putting a jack under only the A -frame part of the suspension and jack it up off the floor. Then grab the top and bottom of the tire and try to wiggle it. If it moves, ball joints are bad.
Old Sep 5, 2010 | 06:29 AM
kickme005's Avatar
Banned
ok thanks will do
Old Sep 5, 2010 | 11:17 AM
ClueMeIn1989's Avatar
ClueMeIn1989 is on a distinguished road
I was gonna add also, if the steering is loose and has alot of slop in the wheel, check out the idler arm for play in addition to the ball joints like croozer said. It may need replacing to hold the alignment you just had.
Old Sep 6, 2010 | 07:01 AM
kickme005's Avatar
Banned
the steering feels stiff
Old Sep 11, 2010 | 04:47 PM
winkeyy's Avatar
winkeyy is on a distinguished road
I have the same problum, all new ball joints and 2 aliments and it still pulls right ! Did you get yours fixed and if so what was it !!!
Old Sep 12, 2010 | 06:51 AM
kickme005's Avatar
Banned
no not yet. maybe i might take it to the dealer when i get a chance
blazen_red_4x4
Oct 13, 2014 12:39 PM
Lawgiver
Jan 20, 2012 09:42 PM
deedub711
Apr 19, 2011 09:11 PM
Marine1975
Oct 31, 2010 11:38 AM
ronkrolock
Jun 11, 2009 06:17 AM
