95 blazer wont go into 4wd hi
Old Oct 18, 2011 | 02:57 AM
redtash1's Avatar
redtash1 is on a distinguished road
Default 95 blazer wont go into 4wd hi
i have a 95 blazer it wont go into 4wd hi,when you push 4wd hi you can hear the relays clicking like its working but light flashes a couple times then goes back to 2wd, but 4wd low works, also before you can try to put it in 4wd hi you have to have it in neutral i know that aint the way its designed to shift...any ideas....thanks in advance
Old Oct 30, 2011 | 09:25 PM
jaydon44's Avatar
jaydon44 is on a distinguished road
if you are not having problems switching between 2hi and 4low then all ur electrical and vacuum lines would be ok, i would check to see what you get for volts at ur actuator when u press all the buttons and maybe that has something to do with it, if the other buttons give you 5 volts but the 4hi button gives you none then you have an actuator problem and if all the buttons are creating volts at the actuator then u probably need a new transfer case
Old Nov 1, 2011 | 03:29 AM
redtash1's Avatar
if i disconnect the battery cable to reset computer it would go into 4wd high one time but not after i took it back out of 4wd hi...so u think it could be the 4wd shift motor
Old Nov 1, 2011 | 09:21 AM
It is very likely that the transfer case encoder motor is at fault. I would recommend running through some of the steps listed in the various NV233 articles in the Tech Article section first before buying a new encoder though.
dj00140
May 20, 2013 06:37 PM
Lone Star Blaze
Feb 1, 2010 06:24 PM
poepoe624
Jan 10, 2010 11:48 AM
Boiler_81
Dec 2, 2008 10:04 AM
AdamM
Engine & Internal
Dec 18, 2006 03:38 PM
