'96 4x4 2 door axle replacement
Old Oct 4, 2017 | 06:21 PM
96twodoor's Avatar
96twodoor is on a distinguished road
Default '96 4x4 2 door axle replacement
I'm going to be replacing the rear end on a 96 blazer 2 door 4x4. What kind of rear end will fit? And are there different gearings in this same year that I should be aware of?
Old Oct 4, 2017 | 06:54 PM
chevyriders's Avatar
Look in your glove box at the RPO sticker and look for one of the following codes:
2.73 = GU2
3.08 = GU4
3.42 = GU6
3.73 = GT4, GQ1
4.10 = GT5
That will tell you your gear ratio. You need one from a truck with the matching code.
Also, if you find one with a G80 code, it also has a factory installed "gov-lock" locker, which will give you alot more traction.
As long as it comes out of a second gen 4x4 s10 pickup, blazer, jimmy, or even bravada I believe, it will fit.
If I were you I would search for a disc brake rear(I believe these became standard in 98) that is a g80
Old Oct 4, 2017 | 07:09 PM
96twodoor's Avatar
Hey thank you for the info. Is there any way to check what diff it is with the VIN number? And if it's a ZR2 or not?
Cheers
Old Oct 4, 2017 | 08:06 PM
If you call a Chevy dealership with the VIN they may be able to help you out, other than that I don't think there's any way to check by VIN.
If it was a zr2, one of the RPO codes in the glove box would be 'zr2' aside from that, it should be fairly obvious, they have fender flares, sit 2.5 inches higher, have a wider stance, and usually (unless someone downsized) have 31" tires. As well as a zr2 decal on the quarter panels.
Now would be a good time to note that the ZR2 package has a wider rear end and will not interchange with the other 4x4s
Old Oct 15, 2017 | 03:02 PM
96twodoor's Avatar
Hey so it has the GU6 3.42 rear end with the G80 locker. Any 3.42 rear end should fit regardless of the G80 locker correct?
Old Oct 15, 2017 | 03:23 PM
As long as it's from another 4x4 yes. however I would recommend finding another one with the g80, just because of the added traction-but it is not necessary
Old Nov 26, 2017 | 12:56 AM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Zr2's came with the 8.5 10 bolt rear and they are approximately 4" wider than a Blazer 4x4 rear axle, no spacers for Vette,Camaro wheels if you are considering that. I will be doing this swap in the future after rebuilding both differentials and installing a Tru-Trac in place of the G-80.
Old Nov 28, 2017 | 08:35 AM
El_Beautor's Avatar
While you are correct that the ZR2 axle is wider than the normal S-series 4x4 axle (4" wider) it is incorrect that they are not compatible. The spring perches are exactly the same, and many people have swapped in a ZR2 axle specifically because they want to improve the factory narrow rear stance. In my opinion it is a viable option, as long as one understands that it will be wider
If his truck has 3.42 gears it is almost certainly not a ZR2. The ZR2s came factory with 3.73 gears, and the previous owner would have had to change them to a different ratio. S-series trucks with 3.42 gears and 31" tall tires (factory on ZR2) significantly lack low end torque, and I am certain that it would not be a factory option.
Old Nov 30, 2017 | 11:12 AM
Now would be a good time to note that the ZR2 package has a wider rear end and will not interchange with the other 4x4s[/QUOTE]
I got a ZR2 axle from a 2 door Blazer for my 4 door. The only thing that is not a direct swap is the rear sway bar. I will need to use the original one and it's mounts to the axle. The exception is the front axle CV shafts and A arms that are a different length on ZR2's
mattyice
May 18, 2015 11:50 AM
blajeans
Jan 9, 2013 12:58 PM
Ryan02Stang
Jun 20, 2012 05:00 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
