97 blazer 4wd front wheel nearly fell off, cv axle?
Old Sep 13, 2011 | 10:17 AM
PubEnemy's Avatar
PubEnemy is on a distinguished road
Default 97 blazer 4wd front wheel nearly fell off, cv axle?
Hello, I drive around 300 miles round trip daily for work. Sometimes I drive up and stay in a hotel and just drive around the construction site all day. Anyways last night as I was leaving I heard a loud POP, my abs light came on I lost brakes almost completely. Luckily I was able to pull off and the left front tire is like this / I have had a grinding popping noise for a month that I thought was the front cv type driveshaft. Since it seemed to have some play in it. I didn't put much more thought in it since I only drive in 2wd. So looking behind the tire thats like this / I can see and area right behind the tire/brake assembly that is seperated/ground up and the abs wire is hanging. Looking at advance auto parts its seems like a cv axle assembly is what I need? Any ideas would be great I can try and get a picture a little later on. Is this a job I can do in a hotel parking lot? Any help would be greatly appreciated.
Thanks
Mike
Old Sep 13, 2011 | 10:21 AM
A picture is worth 1000 words. Can you take a picture? It almost sounds like possibly the wheel bearing had gone bad and since you didn't get it replaced in time, finally fractured and separated. Either that or a ball joint let go.
Old Sep 13, 2011 | 10:45 AM
PubEnemy's Avatar
Its back at the hotel, luckily I made it there. Realizing when I pulled into parking spot I should not have even driven that 3 miles. Smoke was pouring out by time I got there. I will run back there and try to get best picture I can with my phone. Someone said I just need a wheel bearing, but this looks like something that shouldnt have seperated. Directly behind brakes. Like you said a picture and you guys more familiar with the trucks will probably easily pinpoint what I need.
Thanks
Mike
Old Sep 13, 2011 | 10:53 AM
If the bearing separated and you drove it for a while, you may need a new CV shaft, caliper, brake flex line, wheel speed sensor, rotor, hub/bearing assembly, brake shield, and possibly a new steering knuckle.
Here's the break down of the '97 4wd front axle courtesy of CompNine.com: CLICK HERE
Old Sep 13, 2011 | 11:03 AM
PubEnemy's Avatar
Wow great break down, thank you. I believe part 28 the hub kit with sensors etc. is what actually broke. Because ABS light came on and lost brakes, I can see abs wire dangling. If that part broke, I may have to replace most of what is in diagram? At that point It may not make financial sense to fix Pics to come.
Thanks
Mike
Old Sep 13, 2011 | 11:06 AM
There is a lot of stuff in that diagram that you would not have to replace.
If it were me, I would go to a junkyard and find another setup like yours and get the whole thing, maybe swapping out a new caliper & hose as well as a new wheel bearing if the yard one feels the slightest bit gritty.
Old Sep 13, 2011 | 12:21 PM
PubEnemy's Avatar
I uploaded two photos to my photo gallery on here. Im not sure how to link them. But I think it shows pretty decent where its broke. BTW there aren't any junkyards near my home anymore. Not sure about around here where Im working.
Thanks
Mike
Old Sep 13, 2011 | 12:27 PM
I can't really tell from that angle. But from what you have described, it sounds like my original wheel bearing/hub assembly theory fits. The next step is to get it torn down and see what's broken/damaged.
Old Sep 13, 2011 | 12:45 PM
PubEnemy's Avatar
Right where the rubber boot goes into the back of the brakes or hub or whatever is where its broke. Im really at a loss at what to do since its sitting in a hotel parking lot right now with minimal tools etc. available to me.
-Mike
Old Sep 13, 2011 | 12:57 PM
If you can't work on it where you are, I would get it towed.
